Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 07-19-2010, 08:33 PM
dingaling15 dingaling15 is offline
Trying to learn engines
I know how to switch spark plugs and wires, and I know about fuses and how to change them out. I know that I have a V-tec engine in my Civic, but I don't know much else about engines.. does anyone have a minute to give me a rundown on how engines work? I'm just looking for some insight.
Thanks to all who waste their time on me
Old 11-04-2010, 07:59 AM
ZenRookie ZenRookie is offline
Re: Trying to learn engines
not quite sure what your getting at you mean the process of how the engine starts and what not O.o
Or you want to learn how everything works period if so i would say goto school for it.
anyways you turn the key the battery then kicks on the fuel pump on an sends power to the disturb turn the key to start and then the starter turns the engine starting the car.
http://www.youtube.com/watch?v=FfTX88Sv4I8
not the full process but its the basics lol
i would start learning about older engines first if i was you there more simple then todays engines but after a while you'll see its all pretty easy to understand. start with a chevy 350 engine and work your way to computer controlled engines used in todays cars. You could probably get a 350 for about 250 bucks or so from the junk yard. Slowly work on it and takes things apart only a few special tools you might need for it.
Valve Spring compressor
bearing puller
gear puller or steering wheel puller for the harmonic balancer
hm yea thats all i can think ya would need at the moment
just have fun and experiment if you have the money to blow lol
remember its only money
Old 12-18-2011, 08:17 PM
djblancett djblancett is offline
This may sound like a silly reply, but I'd recommend dismantling an old lawnmower engine. You'll get a good understanding of the mechanical process without getting buried under multiple cylinders. all four-stroke engines have the same operating principle, but carburetion as opposed to fuel injection changes a few things, and crank position sensors as opposed to distributors also complicates things.
Once you understand the basic operating principle, the rest is easy. Multiple cylinders can be arranged in-line (4cyl, 5cyl, 6cyl,etc) V configuration (4-6-8-10-12 cylinder engines, always even numbers) and horizontally opposed (VW, Porsche etc)
Air cooled? liquid cooled?
That's why I'd recommend an old Briggs and Stratton to cut your teeth on. Go with a junker because you might want to mow the lawn with that new lawnmower, and the reassembly might not go well the first time you do it.
Tags
beginner , civic , engines , honda
