Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 01-18-2011, 12:26 AM
Crazy667 Crazy667 is offline
Exclamation 2009 civic engine in a 95
I know a guy who is claiming that he has a 95 civic with a 2009 civic engine witha six speed manual...now i dont know much about hondas but my question is if anyone knows the possibility of someone doing this and approximation of what is would cost. Thanks in advance.
Old 01-18-2011, 02:24 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 2009 civic engine in a 95
It can, and has been done, but it is not a cheap or an easy swap.
You need a fairly high level of engineering knowledge, skill and tools to make it work as the K20 is in no way compatible with anything in an EG or EK so everything has to be custom made, mounts, linkages, the lot.
Old 01-18-2011, 01:54 PM
well this is a redneck from iowa that gets high for a living so i was just wondering if was with in his capabilities...obviously its not lol
Old 02-11-2011, 04:00 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
That's easy stuff, especially for a shop to do. A LOT of parts are made nowdays for K-series swaps into EG and EK chassis civics.
What you are talking about is a K-series swap into an EG. The K-series w/ a 6 speed has been out since the RSX Type-S was first introduced circa 2002, hasport followed with mounts a year or two later. Now a K-series in an EG or EK is pretty common. You can buy the mounts and lots of other required parts nowdays, so there is a lot less custom fab involved than there was 6+ years ago.
The Acura RSX comes with a K-series (K20A3 for 2002-2004, K20Z1 in 2005-2006), though it's a toned down version. The 2002-2005 Si hatchback came with the K20A3. The RSX Type-S had a good, hopped up K series with a 6 speed (K20A2). It put down 200hp, whereas the K20A3 put down 160hp. The 2006-2010 Civic Si has a K20Z3 with a factory LSD in the transmission.
The newer CRV came with a K24A1 ( K24Z6 for 2010+ CRV), and the Acura TSX came with a K24A2 also came with K-Series motors (The CRV had a K24). Some guys will stick a K20 head on a K24 block (some idea as an CR/Vtec from back in the day).
To swap a K-series with 6 speed into an EG will probably run in the $7,000-8,000 range if you are paying a shop to do it (which I'd recommend if you haven't any engine swapping experience). A K-series swap is harder for the DIY type person than a B series swap is.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 06-25-2016, 05:29 PM
jasonnastley jasonnastley is offline
It is possible but it is exorbitantly expensive !
Old 06-27-2016, 02:12 PM
MikeCStig MikeCStig is offline
Yeah, a redneck who gets high for a living would never take on a swap so ambitious and expensive. It can be done, but it's very difficult and requires a lot of customization to make it work.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Tags
1995 , 2009 , civic , engine , swap
