Old 07-05-2002, 03:32 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
92 civic engine......questions.....
will this fit? what is needed and ow much work is involved?
also do you think 450.00 is a good price? (23,xxx miles)
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 07-05-2002, 03:58 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
what model is your hb ? si, dx ? what model car is the engine coming from ? ex, dx ? but yes a 92 civic motor will fit in your car, and you can use your stock tranny. is it a complete motor ? $450 is good maybe alittle high if your getting the d16z6 sohc vtec, if its a dx motor then thats way to high
GTA's Avatar
GTA GTA is offline
Whee..
Yea a 92 civic engine will fit. Only one thats really worth it is the d16z6 which is the sohc vtec one.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 07-05-2002, 06:23 PM
its coming out of an ex, and yes its a vtec, so that price is about average? also, do these engines have any problems i should take into consideration? and...one more question...is a 88-91 hb std lighter than a 92 hb ex?
Old 07-05-2002, 06:27 PM
oh yea, and does it bolt right in? and what all would i need other than a cpu and vtec controller?
Old 07-05-2002, 07:01 PM
GTA's Avatar
GTA GTA is offline
Whee..
a 88-91 std is lighter. it will bolt right in. Just make sure you swap to MPFI of you still have DPFI. Other than that, i think all you need is the ecu and some type of vtec controller
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 07-05-2002, 07:22 PM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
you might wanna think about getting the wiring harness if you are changing from DPFI to MPFI. It will make things easier. Also, I think you will need a resistor box. If your using your tranny, yu should have no problems with axles. But, if your going 4spd to 5spd, I woud check and see if they are the same. I'm switching from D15 t D16A6 soon so these are my concerns. Good luck and keep us up to date.
Old 07-06-2002, 07:06 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
no...it's one way or the other.
you can used the ecu (or as you put it, cpu) and distributor from the z6 and get a wiring harness so that you adapt the ecu to work
OR
use a 4th gen ecu, distributor, and a v-tec controller
the p28 (sohc v-tec ecu) controls the v-tec and no need for a v-tec controller if you use it.
any other questions? just did the same swap a couple of months ago. click the >v-tec inside< link in my sig. to read about the 3 day experence
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-07-2002, 03:18 AM
hehe, ecu cpu.....all in all its the same thing, i just got home from work when i posted that so i was in a computer state of mind, anyway....ami, thats the same engine i am getting isnt it>? how much faster are you and what kind of #'s do you run?
Old 07-07-2002, 12:19 PM
amy@af's Avatar
i have no idea what numbers i run. one of these days soon, the car will go to the track. however, i'm one of those people who builds their car for personal pleasure...not to shave seconds...ya dig?
i have noticed a difference in the a6 and y8. let's not even get into v-tec. :licker: we all know that factor. the a6 and y8 are extremely close, a lot of the parts are the same. so i really just expected the y8 to act like the a6 with and extra kick when v-tec engages. i was wrong. noticed first thing that the y8 opens up a little quicker.
i almost felt like i did when i went from driving dx to si. it's no huge difference...but, if you know your car...you'll feel it.
ami
2009 civic engine in a 95 Crazy667 JDM Motor & Parts info/chat 5 06-27-2016 02:12 PM
Trying to learn engines dingaling15 How-To's and Walk-Through's 2 12-18-2011 08:17 PM
2005 Hybrid with recurrent engine/IMA lights SheltieMan '01-'05 Civic 1 07-14-2010 08:54 AM
Civic Hybrid Cars-- '06+ Civic 0 05-04-2009 07:30 AM
95 civic ex engine questions ndekens '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 13 10-13-2002 11:42 AM
