Old 10-05-2002, 04:56 PM
89bxci-vic 89bxci-vic is offline
Send a message via AIM to 89bxci-vic
Question dual point to multi point, someone help!
Can anyone help me wire up a 5 speed b18a to my 89 dx,auto, hatchback. detailed instructions please.
you almost beat me?
you never had your car!
Granny Shifting! Stressed cause your girl's on my lap! Don't worry you'll catch'em in the turns, slow cars can be fun too!
Old 10-05-2002, 06:14 PM
kris's Avatar
kris kris is offline
Off playing with fire.
These are diections for DPFI to MPFI with Si parts.
complete intake manifold (TB, fuel rail, injectors, all sensors!)
injector resistor box
88-91 si ecu
88-91 si distributor
a few connectors from the Si engine harness and an si coolant hose to connect the manifold and the block u can use ur stock and cut it if ur cheap
its pretty easy! drain the raidiator and all then take off the intake manifold and put the si intake manifold on and rewire everything. dissconect all the plugs from all the sensors and the injectors make sure u diconnect the coolant lines from the intake and there is one bolt that holds the manifold to the block underneath you will not see it unless u know about it.
In order to convert your dual point injection DX to multi-point injection you will need 4 injector plugs, an injector resistor box, extra wire, and electrical tape(heat shrink is best).Also, when doing this conversion I would highly recommend soldering all connections and heat shrinking them. It is good to have an extra multi-point injection engine harness laying around to take plugs off of(injector plugs, injector resistor box plug, and distributor plug u can use ur stock dist plug if u cut one off another dx dist and use it to plug in but ull need a 2 wire plug for the ca sensor).
Pins B10 and B12 are empty. Unused pins can be taken from B2 or B11. Sometimes there is a unused wire at B12. Cut orange and white wires off at C1 and C2 and connect them to wires added at B10 and B12. Orange-B10. White-B12. Leave enough wire for next step.
Run wires from C1 and C2 on the ecu into the engine compartment. Label these wires for later use. Cut wires at A3 and A7 leave excess for later use. Run these wires into the engine bay and label them to be used later on .
Under the Hood
TPS and EACV plugs are too short and must be extended. Be sure to switch green/white and yellow/white wires on TPS since the dx turns the opposite way.
Injectors and injector resistor box
Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box. Connect the yellow wire from the DX injector to the #1 injector (brown wire). Connect the red wire from the DX injector and run it to the #3 injector (blue wire). Connect the A3 wire to the #2 injector (red wire). Connect the A7 wire to the #4 injector (yellow wire). Connect the 4 red/black wires from injector resistor box to each injector.
Cylinder position sensor
Connect C1 to blue/green wire on cylinder position sensor plug. Connect C2 to blue/yellow wire on cylinder position sensor plug the rest of the wires are color matched for your dx to the si wires
THIS INFORMATION IS FOR RESOURCE AND PERSONAL USE. I AM NOT LIABLE FOR ANY DAMAGE TO YOUR CAR OR OTHER PROBLEMS RELARED TO THIS CONVERSION
Multi Point over Duel Point Crx Guy '88 - '91 Civic | CRX | Wagon | Shuttlee 4 02-24-2006 01:50 PM
dual point to multi-point motor swap wickedplastikman '88 - '91 Civic | CRX | Wagon | Shuttlee 4 06-14-2004 11:38 AM
more dual point to multi point bulsh*t... 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 04-07-2003 12:03 AM
changing from dual point to multi point 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 09-11-2002 02:16 PM
dual point to multi point? DarkImportGrey '88 - '91 Civic | CRX | Wagon | Shuttlee 3 07-23-2002 07:51 PM
