Old 05-23-2004, 03:43 PM
wickedplastikman wickedplastikman is offline
dual point to multi-point motor swap
i am giving my crx si motor to my friend since i owe him some money and he wants me to help him swap it into his 89 (i think) hatch. the hatch is dual point fuel injection and the si motor is multi-point. i am looking to clear up some confusion on a couple parts before i get started so i can use some help.
engine wire harness (can i use the one from the hatch)
shift linkage (can i use the one from the hatch)
i have the ecu and other parts already but i was confused about these. also, do i need the part of the wire harness that goes through the firewall too or is the one in the hatch ok?
thanks.
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
Old 05-23-2004, 09:25 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
This page will tell you everything you need to get/do to do the swap.
http://www.fourthgenhatch.com/mpfi.html
KoRnSaQ
Old 05-24-2004, 02:54 AM
Re: dual point to multi-point motor swap
thanks.
99 teg ls turbo:
Old 06-14-2004, 12:46 AM
if i buy another wiring harness do i also need the piece that goes through the firewall too? if i keep it, will i have to repin it?
99 teg ls turbo:
Old 06-14-2004, 12:38 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
just use the wiring harness from his DPFI motor and convert it to MPFI with the above directions.. that's the simplest way to do it
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
