Old 09-27-2002, 05:28 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Help! Smoke! WTF?!
Okay... Story time:
On the way down to K-Falls a couple weeks ago, I got stuck in rush-hour traffic in Portland. Me an my buddy Shaun are pretty much stuck at a stand-still on the freeway, and I keep seeing these tiny wisps of smoke around the steering-wheel/steering column area. At first, I thought I was just trippin', then I thought maybe I dropped a cigarette or something... Shaun couldn't see them for a while, then he saw the smoke. It was so hot out, and I had cool air blowing on my legs, I thought maybe it was steam or something from my sweat. I couldn't smell anything burning...
Then, on the way back from K-Falls, my tach started freaking out. I never actually saw it happen, just out of the corner of my eye, I'd look over, and the needle would jump from zero up to where it was supposed to be at the very instant that I looked at it. Again, I thought I was just trippin' out.
Today, on my way to work, the tach jumped again, I saw it happen this time and I was like WTF?! Then, when I pulled into my parking space, I saw smoke coming out of the steering column (through the hole for the headlight control arm), and I could smell something burning... deffinitely electrical.
Anywho, I shut the car off and it stopped smoking. I sat there for a good ten minutes just to be sure. I took a quick look at the fuse panel and stuff, but I didn't see anything wrong...
What the hell is going on?!
I figure I'll pull my guage cluster tomorrow, and check the tach wiring or something...
Old 09-27-2002, 05:35 PM
bc4g bc4g is offline
smoke anywhere but especially from the steering column could be serious? Does it do it in the hot temp. only? Is your temp gauge reading normal?
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 09-27-2002, 05:36 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
My car does the tach shit when i am idling for a while, it will slowly inch down to zero, then go back up to normal, but as far as the smoke goes I dunno.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 09-27-2002, 06:38 PM
ci5ic's Avatar
Chad
Temp guage is completely normal, first thing I checked...
I'm thinking it's most likely a short in some of the wiring to the tach (or something on the same circuit)... the other guages don't seem to be affected by it.
Don't know if it is related to "hot" weather, I've only noticed it a few times, but it has been hot when I've noticed...
Old 09-27-2002, 07:35 PM
Brad McCoy Brad McCoy is offline
I had the smoke thing happen to me this summer, only mine was related to my blower(fan) switch - sometimes it worked and other times it wouldn't (I had to have the key in a "certain" position for it to work).
Any way, I replaced the ignition switch (AutoZone ~$50) and everything is back to normal. I also found a small "ball" of solder laying in the fuse panel cover when I removed it. Hope this helps.
Old 09-27-2002, 09:23 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
I had this happen to me, and this was a while ago on the DX, and when i finally pulled over to check it out, somehow a wire from my foglights burnt up... i was like ??? but i replaced that wire and all was good again! So, sorry, can't help ya, but check for any burnt wires!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 09-27-2002, 10:13 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Where do you have your tach wires run? could they be burning up and causing the smoke?
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-27-2002, 10:29 PM
ci5ic's Avatar
I dunno, I've never looked...
oh, and BTW, it's the stock tach, not an aftermarket one...
Old 09-27-2002, 10:46 PM
gunnmen01's Avatar
mmmm stock tach, anything else wired into guage cluster?
indiglos or anything?
gunnmen01
Old 09-27-2002, 10:59 PM
ci5ic's Avatar
Negative.
Old 09-27-2002, 11:18 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i asked jer. he has some trouble shooting questions. the first...is your car running rough or running right?
we can whore up the thread and play post tag or you can hit me up by e-mail...either way, you can pick his brain and this is right up his alley
you really need to download aim
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-27-2002, 11:25 PM
ci5ic's Avatar
I don't think I can use AIM at work (firewalls suck).
Anywho, the car runs fine, as far as I can tell, and I usually notice any small change in the way it runs. The only symptoms I've got so far are the smoke and the tach turning off and on...
I'm pretty sure I'll be able to find it, I just need to get in there and look. Like I said, it happened on the way into work, so I won't get a chance to do it until tomorrow.
Is there a fuse for the guage cluster? I was thinking about disconnecting the power to the guages so that I can drive the 15 miles home, and hopefully not worry about my shit catching fire.
Old 09-27-2002, 11:36 PM
amy@af's Avatar
that does suck.
he says the only thing you can do is pull the panel at the top of your dash...and pull the plug on the left. i've heard you talk about pulling apart the dash and cluster...so i'm sure you know what i'm talking about
Old 09-30-2002, 04:18 PM
ci5ic's Avatar
I figured it out.
I pulled apart my guage cluster, completely unplugged it etc. problem still occurred. Pulled apart the steering column, and noticed that the ignition is fried. One of the solder joints on the back of the ignition got hot enough to reflow the solder, and it bridged to an adjacent solder joint. I'm not sure what the part is called, but it's a round switch looking thing, and about 7 or 8 wires from under the dash are soldered to it. It is held to the ignition by 2 brass screws, and there's a tiny hole in the center of it that part of the ignition goes into. I'll post a pic in an hour or two...
Thanks for the help everyone!
Old 09-30-2002, 05:03 PM
Honda calls it a SWITCH COMP., STEERING part # 83845 ~$42 from Majestic Honda.
I paid~$50.00 from AutoZone and it is called an ignition starter switch, mfg: Wells, part # LS883.
Hope this helps!!!
Intermittent white smoke. WTF? 9396 ULTRA Suburban 6 09-29-2006 10:17 AM
my vent air smells like black and mild smoke.... wtf??? Young Chuck D Cavalier Problem Diagnosis 6 07-20-2006 12:02 PM
Wheel Help //// Smoke... Asap Help blindfoldedhope Probe 0 11-13-2004 12:13 AM
Can't rev past 2500RPM and balck smoke! WTF?? Import2nr99 Off-Topic 13 08-28-2004 09:20 AM
Help...smoke coming out of intake manifold? ddustin Integra 0 11-07-2003 09:42 PM
