Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-23-2006, 10:10 AM
9396 ULTRA 9396 ULTRA is offline
Intermittent white smoke. WTF?
Took the new rig on a run to the dump and on the way there it started blowing white smoke. Temp was normal, I was fixing to shut it down, the SES light came on and the smoke quit!
Made it back home with no problems, except every couple of minutes it would start blowing smoke like crazy and then quit.
Once I got home the cat was hot enough to bake a pizza under,and I had tranny fluid and motor oil leaking from all over the place.
The radiator did not boil over and I pulled a code 32 and a code 43, which really sucks because I just changed the EGR valve and the knock sensor this morning.
This one is just plain weird.
Any ideas?
Old 09-23-2006, 10:43 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Intermittent white smoke. WTF?
Any ideas?
What year is it, and what transmission does it have?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-23-2006, 10:47 AM
89 suburban TBI 350, 700R4
Old 09-23-2006, 02:27 PM
maxwedge maxwedge is offline
A990 racer
Question Re: Intermittent white smoke. WTF?
Any ideas?
Loose any coolant?
Old 09-23-2006, 06:36 PM
Nope didn't lose any coolant.
Old 09-29-2006, 09:56 AM
KeySub KeySub is offline
Take a good look at your trans fluid level...
On mine the PO had lots of fun with something similar... had the heads done... spent a ton of $ and it turned out to be the diaphram in the vac modulator on the transmission, drawing ATF up the vacum line and burning it!
Just keep an eye on that?
Old 09-29-2006, 10:17 AM
silicon212's Avatar
Confoundingly Lucid
That's what I was getting at. The only transmissions that he'd have with a vacuum modulator are a TH350 or 400.
