Old 12-01-2002, 08:27 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
Parts for Sohc vtec head swap
just curious what do you think i should replace when doing the d16y8 head swap???
Old 12-01-2002, 09:08 PM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
well...being you have the si...do the timing belt and head gasket obviously...good choice on the y8 atleast your dizzy will bolt up....if you have the resources...do everything that you can to the head while its out...I did the z6 head and after a few minor bugs it runs strong
"Faster and Faster until the thrill of speed overcomes the fear of death" Dr. Hunter S. Thompson
Old 12-01-2002, 09:46 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
id do it all. timing belt, water pump, thermo stat and gasket, new drive belts ...but thats my opinion...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 12-02-2002, 02:39 AM
he's right seeing how you're already in there and got the crank pulley off and its all apart you should do everything......my water pump was missing a bolt when I went and did my head swap...haha...but the bolts that hold on the timing belt cover are the same and I have lots of those..you could see where it had been leaking....
Old 12-02-2002, 11:58 AM
12secondSupra 12secondSupra is offline
Banned
http://www.automotiveforums.com/vbulletin/t76330.html
Old 12-02-2002, 12:46 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
12secondSupra this is your warning. knock your shit off. i see anymore and your banned.
some how i get the feeling you don't have a supra or even a car, generally those who talk as much as you are 15 yr old kids who don't even drive.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 12-02-2002, 12:56 PM
91zc 91zc is offline
hahaha...someone is in the process of getting owned
As for what I would replace during the head swap:
Thermostat
Water Pump
Timing belt obviously
Valve cover gasket and spark plug tube seals
Distributor cap and rotor
Head gasket
Alternator belt
Check the front main seal for leaking oil(behind crank pulley)
Spark plugs and wires
91 civic 4dr
b16a
14.8@94
Old 12-02-2002, 09:16 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Will the Si dizzy bolt up to the D16Y8 head? I didn't think it would, but even if it does, you won't have all the sensors you need right? I was curious though, since I may need to buy a new dizzy for my z6, could I just buy a y8 one and install it, but not hook up the OBD2 sensors (so that I don't have to buy one for the z6 and then buy one for the y8)?
Any ideas?
Old 12-02-2002, 11:19 PM
amy@af's Avatar
i have an a6 dizzy on my y8 block.
most important mike...you keep the same dizzy with ecu. so either a6 dizzy & pm6 ecu OR the p28 and the z6. we've tried mixing and matching several parts. the one thing we learned is you can't mix dizzy's and ecu's.
