Old 09-21-2002, 07:39 AM
Luka3000gt's Avatar
Luka3000gt Luka3000gt is offline
Banned
3 very quick primer questions!!
Is better primer a model whith an airbrush or whith a can?
If the answer is airbrush; what are the tamiya codes for the primer?
Is better a white or grey primer?
Old 09-21-2002, 08:19 AM
rcmaxx rcmaxx is offline
1I dont know of any airbrush primer.
2 there is none, you have to use the spray can and airbrush the color.
3depends on the paint your working with.
Old 09-21-2002, 08:27 AM
ZoomZoomMX-5's Avatar
In most instances you'll get a better finish by airbrushing primer. But Tamiya primer works so nice that if you can find it, use it. Otherwise automotive primers will work, get the lacquer/sandable kind. You can spray that paint into a container and apply it w/an airbrush, though sometimes I've needed to add a universal retarder to the mix so the paint flows smoothly.
Use a primer color complementary to the final color. White works best for light colors and bright/warm-hue colors, such as white, yellow, orange, red. Use gray primer for blues, greens, purples, black. Some primers are available in black and red oxide, use black for really dark colors or black, and red oxide for maroon colors. Some people use a pink primer for bright reds, like Ferrari red. Your top color will be best if you use the correct primer. If you have a particular color you want to spray and can't decide on the primer color, ask here!
Old 09-21-2002, 09:37 AM
935k3's Avatar
935k3 935k3 is offline
There is one primer for airbrush that is very fine and high quality, it is made by Floquil and is in their Rail Road color line. It is a very light grey. It's very good stuff and works under about any type of paint you can think of, it should be thinned with their thinner called Dio-Sol.
Dio-Sol is also an excellent thinner for Testor's Enamels.
Old 09-21-2002, 12:21 PM
Luka3000gt's Avatar
Banned
Hey, 953k3, very thanks for the suggest, where I can find it on the net?
Old 09-21-2002, 12:34 PM
935k3's Avatar
I did a search on Google.com and found tons of places that carry it. I am used to being able to walk in a hobbyshop and get it especially shops that specialize in Model Railroad stuff.
Old 09-21-2002, 12:40 PM
935k3's Avatar
I also forgot to mention it drys very fast and use a low pressure
15-18 PSI when you spray it.
Old 09-21-2002, 01:26 PM
Luka3000gt's Avatar
Banned
It's a bit complicate, excuse me can't I use a tamiya gloss (mutt) white or gloss(mutt, I don't know the exact word) grey?
Old 09-21-2002, 02:14 PM
Mikke Mikke is offline
Send a message via Skype™ to Mikke
There's also this:
ModelMaster White Primer
I don't know about the quality, though.
Oh, and it's available in gray, also.
8.10.2003 13:44:25 Ales says: and with some work I'd be a great model
8.10.2003 13:44:36 Mikke says: no you wouldn't
8.10.2003 13:45:00 Ales says: good point
8.10.2003 13:45:01 Ales says: LOL!
Old 09-21-2002, 02:45 PM
935k3's Avatar
Originally posted by Mikke
There's also this:
Testor's primer is not really primer it is more of a semi-gloss it goes on with a texture and does not sand well. Don't use it.
Old 09-21-2002, 02:47 PM
935k3's Avatar
You don't want to use anything gloss for a primer.
Old 09-21-2002, 04:07 PM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
its also acrylic base so it wont stick to the plastic that well either, another popular bottled primer is Gunze Sangyo Mr. Surfacer. it comes in 2 different grits 500 and 1000, the 1200 only comes in sprays.
Old 09-21-2002, 10:06 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
I second that! it goes on like shite and wont come off with sanding, but will chip off on corners. use tamiya or Gunze if you can find them. best1hobby.com carries both as far as i know.
Very quick question theT Car Modeling 3 09-10-2003 05:21 PM
Skunk2 springs got here today. VERY quick question 90gs Integra 2 08-14-2003 01:29 PM
Quick Paint & Primer Question dannysreallycool Car Modeling 4 07-15-2003 12:07 AM
one quick primer question 87beastaccord Car Modeling 2 05-01-2003 12:05 PM
R33 Skyline GTST VERY QUICK CAR (208kw at wheels) QUICK33 General Discussion 7 01-30-2002 10:35 PM
