Old 07-14-2003, 06:44 PM
dannysreallycool's Avatar
dannysreallycool dannysreallycool is offline
Send a message via AIM to dannysreallycool Send a message via Yahoo to dannysreallycool
Quick Paint & Primer Question
ok i just have a really quick question, if i primered my model car do i have to paint it with automotive paint because i primered my skyline and my mom bought me testors enamel spray paint could i spray it over the primered car or no? and should i use testors or is there a better spray paint out there?
Thanx In Advance
Old 07-14-2003, 06:54 PM
jdmwhizkid's Avatar
jdmwhizkid jdmwhizkid is offline
You can use any type of paint over primer as long as the two are compatible. You should use the same type of primer and base/top coat (ie. enamel-enamel acrylic-acrylic) or some bad things could happen. There are some exceptions though. So I guess the answer would be no, you don't have to use automotive paints. What kind of primer did you use? The Testors spray paints aren't up to the quality of Tamiya spray paints, but usually get the job done and turn out well. Good luck on your Skyline!
Old 07-14-2003, 07:07 PM
i used $1.50 sandable primer from a local hardware store called OSH it justs says Painter's Touch: Sandable Wet-Dry Primer GRAY
Old 07-14-2003, 10:16 PM
jdmwhizkid's Avatar
I'm not sure but it should work. Maybe prime some spare parts or sprue and then spray your body colour on that just to test it and see if it works.
Old 07-15-2003, 12:07 AM
its so far so goood . . .
