Old 04-30-2003, 01:32 PM
87beastaccord 87beastaccord is offline
Send a message via ICQ to 87beastaccord Send a message via AIM to 87beastaccord Send a message via MSN to 87beastaccord Send a message via Yahoo to 87beastaccord
one quick primer question
okay, when i got my model i had no idea about painting models the righ way. i am learning a bit more as i go. when i first got it, i sprayed it with some enamel paint. then i realized i should use primer and stuff so i sanded off alot of it. then when it was mostly sanded i primed it. then the primer coat of painted cracked up in some spots. so i sanded out those spots and sanded much of the primer smooth again, using 400 grit. anyway, now i am looking at it and its three different colors, white(plastic), black(paint) and grey(primer). so now do i prime it again and paint it or do i clean it p a bit and paint it now? i want a really shiny smooth paint job
current project s10 extreme. 70% done..
mods:
BBC 454 from another kit
Tri-carbs intake from another kit
modified transmission
drag slicks on back
custom hood scoop(to clear engine)
custom interior with NOS botttle + more
real working subs in taneauv bed cover
custom clear tailights
Old 04-30-2003, 01:36 PM
freakray freakray is offline
AF Modelrater
I would recommend you strip completely and start again from bare plastic.
You can strip enamel paint off with Castrol Super Clean degreaser.
I would also recommend you read the FAQ to see all the info on painting already there.
AF User Guidelines
Old 05-01-2003, 12:05 PM
z_dutchie's Avatar
z_dutchie z_dutchie is offline
Try using 1200 gritt thats wat I use mostly
Frank
feel free to use my name
user bars rock
