Old 09-05-2002, 05:45 AM
Robert XR4x4 Robert XR4x4 is offline
Send a message via ICQ to Robert XR4x4
T5 gearbox to cologne 4.0 V6
Hi
I am trying to get a bellhousing so I can fit a T5 gearbox to my 4.0 cologne engine, same pattern as the 2.9. Did any American cars have a T5 box with the 2.9 v6?
or can anyone point me to a supplier in the uk
cheers
Robert
Sierra XR4x4 4.0 Twin Turbo
www.xr4x4.co.uk
Old 09-05-2002, 06:11 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
T5???
The only t5 i know of is the Toyota 5sp found on some of the RWD 4age powered Levins Trueno etc from the 80's.
Its a VERY stong g/box capable of handling 300hp with out complianing and is a commonly used on the old Rover V8, and many small block chevs.
Here in NZ there are a variety of place's that make conversion plates that allow it to be bolted to any engine you want.
If that's not what your talking about then prehaps elaborating a little more would be helpful.
Old 09-05-2002, 06:52 AM
sorry, I am talking about the Borg Warner T5 box that is used in RWD Sierra Cossies and I believe is used in things like Mustangs
cheers
Robert
www.xr4x4.co.uk
Old 09-05-2002, 05:51 PM
replicant_008's Avatar
replicant_008 replicant_008 is offline
T5
Moppie, the T5 is the BTR Australia (previously Borg-Warner) 5 speed gearbox which was until recently found in all manual Falcons (the XR's now have the Tremec 3650 and I'm not sure what the Forte etc use) and was used in the Commodore prior to the switch to Getrag 5speed in VR. The Tremec 6 speed in the SS is another gearbox again.
The T5 was also used in some of the Fox Mustang's too. It's a reliable gearbox which is capable of handling a fair amount of torque (including the EB III on 302W).
I think the gearbox you were thinking of is the Celica 5 speed which came in steel and alloy cases. (There's one in the race-car and also two more in several pieces in the workshop until we worked out a fix - well we hope it fixes the problem!)
As far as I know the Cologne V6 wasn't widely used in the US but was confined to Capri, Cortina and Sierra in Europe - I could be wrong but there aren't a lot of RWD Ford Platforms except Mustang and Crown Victoria (and I think the Mustang used a six in a few models).
Robert, you could try contacting Quaife in the UK - they do lots of bits in this area (eg Aisin-Warner 6 speed conversions etc) or they could probably put you in the right direction. I used to have one of their catalogs but this got cleared out when I relocated offices - but they are on the web.
Best of luck and let us know how you get on... incidentally this isn't for the XR4x4 because the T5 is a RWD box? I seem to recall the XR4x4 used a Ford sourced MTX75 box...
Old 09-06-2002, 03:17 AM
Hi
thanks for the info, I never thought to contact Quaife, i'll give them a call
You are correct, the XR4x4 does use an MT75 box. I am building a 4.0 SOHC (from an explorer) twin turbo engine for my XR4x4 and I want at the same time to convert to RWD. I have considered a RWD MT75 gearbox but they are very rare to fit the V6 engine as most were automatics. The T5 should be able to handle the estimated 300-350bhp better than the MT75 as well
cheers
Robert
www.xr4x4.co.uk
1999 4.0 GC larado Cam and crank positioning sensor szellers73 Grand Cherokee | Grand Cherokee SRT8 4 01-19-2010 10:30 AM
93 Yj 4.0 starts with high idle... IntenzInc Wrangler 0 04-04-2009 12:06 PM
98 4.0 to 94 4.0 gc will it fit? help jeep pros rrruschman Grand Cherokee | Grand Cherokee SRT8 1 02-25-2005 08:15 PM
Can I exchange my Cherokee Country 4.0 liter engine w 96 4.0 liter grand cherokee eng 96jeep Cherokee 2 02-01-2005 11:56 AM
4.0 4spd automatic OR 4.0 5spd automatic?? kne831 Aerostar 0 01-09-2005 03:27 PM
