Old 09-05-2002, 02:04 AM
CRXkid CRXkid is offline
Send a message via Yahoo to CRXkid
getting my b16
Tomorrow I'm going to put a down payment on a b16a for my CRX. I'm real excited. I was wondering if anyone has any advice on things i should get done with the swap. Like I've heard its good to change the timing belt. Anything else I should do? Thanks.
Old 09-05-2002, 04:10 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
you could change the water pump too. if you got the money then you should buy a new clutch and put in a lighten flywheel
Old 09-05-2002, 10:34 AM
91zc 91zc is offline
I would change:
Water Pump
Timing Belt
Thermostat
Cap and Rotor
Spark plugs and plug wires
Valve cover gasket and spark plug tube seals
Oil pan gasket
Alternator belt
Clutch and resurface flywheel(or buy aftermarket lightened flywheel)
There are other things you might want to replace but it all depends on how much you are looking to spend on replacing parts.
91 civic 4dr
b16a
14.8@94
Old 09-05-2002, 04:33 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i highly agree with everything 91zc suggested. depending on how mechanically inclinded you are, you might also want to replace the head gasket.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-05-2002, 05:03 PM
QuickSilverEF9 QuickSilverEF9 is offline
Send a message via AIM to QuickSilverEF9
Putting a down payment? So what you are going to make payments on your swap??!! :sun:
1997 Golf GTI VR6
-Leather Interior
-47000 miles
-JVC KDSH707 Head Unit
ON THE WAY
-2xInfinity Kappa Perfect 6.1 components
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Brock B2 deep dish wheels
-Suspension.....
Old 09-05-2002, 06:36 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Hey, don't knock it!
I've been making payments on my D16y8! But that's mainly cuz I don't wanna shell out all the money at once, but I don't want anyone else to come along and snag it out from under me either... It's a sweet deal.
Old 09-06-2002, 12:11 PM
Haha, no, there wont be like any monthly payments. I just put a down payment so that they would hold theengine. They also wanted a down payment before they get all the parts, I guess they want to make sure I'm serious.I'm getting a new water pump, timing belt, and clutch so far. Thanks for the help.
Old 09-06-2002, 03:02 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I just slapped the motor in there without changing anything. I'm not sayin don't change it but i did cause i'm tearin the motor apart over the winter.So i'm gonna change all that is required then. I got something comin for those "turbo" lovers out there!
Old 09-06-2002, 04:29 PM
amy@af's Avatar
you might want to add thermostat to the list. it's generally changed at the same time as the water pump...and it's cheap to just get it and not have to worry about it in the future.
which should i get b16 or the b18 tightsol7 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 12 11-18-2003 04:20 PM
fix smoking b16 or get a new one or b18 nightkidEf9 '88 - '91 Civic | CRX | Wagon | Shuttlee 12 10-29-2002 03:44 PM
fix b16 or get a new one nightkidEf9 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 10-24-2002 09:59 AM
Getting A B16!!!!!!!!!! slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 6 07-28-2002 07:57 AM
Where can i get a B16 or a B18C1?? MJ23FE Engineering/ Technical 3 07-15-2002 02:13 AM
