Old 09-04-2002, 09:13 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
can someone please help me?!?!?!?
ok, hey heres the deal, my car sputters like a bitch when giving it gas below 3500 RPMs, above that it runs well and takes off like a bat out of hell, i got new plugs, and wires, and treated it with 2 bottles of stp fuel system cleaner...what could this be?
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 09-04-2002, 09:31 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Check you distrib and cap get some alcohol clean it really good and reinstall. If it runns good get new ones that alcohol trick will only last a couple of days. It clean the cracks in your cap but if they are there it will collect dust again and cause it to mess up again. If thats the problem that is......
Old 09-04-2002, 10:00 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i just figured it out :jump: for audi. for those wondering...he's running the wrong distro.
he is using the 88-91 Si ecu and a d16z6 distributor. when i first did my swap i had troubles because i tried a p28 ecu with my a6 disto. same problem. you can't mix and match the distro's. most of all the other parts you can mix and match to some degree.
just thought i'd mention that for all who plan on doing that swap sometime soon
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-04-2002, 10:25 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
So, what setup would you recommend for my D16Y8 Ami?
Should I go with the P28 ECU and the Y8 dizzy?
Or, could I use my Si dizzy and ECU?
Or, should I use the Z6 dizzy and some other ECU?
Can someone please help me gem2316 C/K 5 03-01-2004 11:17 PM
Can Someone Please Help Me?????? RXSilver Grand Cherokee | Grand Cherokee SRT8 0 10-27-2003 11:23 PM
can someone please help me fix my heater Redline_civic91 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 10-10-2003 10:10 AM
Can Someone please help me davehewitsonuk Graphic Manipulation 3 12-07-2002 09:16 AM
Can someone PLEASE help ME? kiang Integra 3 10-02-2002 12:43 AM
