Old 02-25-2004, 01:09 PM
gem2316 gem2316 is offline
Send a message via AIM to gem2316 Send a message via Yahoo to gem2316
Can someone please help me
I have a 1990 chevy truck with a 350.. i've been dealing with this miss forever i have sent it to the shop and it ran good for a few monthes then back to the samething.. i have replaced the distributor, cap, rotor, plugs throttle body.. The last time around after changing the throttle body it ran good with still a slit miss after i drove it for a while the miss returned.. changed the throttle body again miss was still apparent. so decided to check the plug when i removed the plugs the number 7 and 8 plug where both a little wet 7 more then 8.. the truck seems to run fine without load and at higher rpm's it runs great just seems to be at lower speeds and idle
Old 02-25-2004, 01:14 PM
okie-chevy-man okie-chevy-man is offline
Banned
Send a message via MSN to okie-chevy-man Send a message via Yahoo to okie-chevy-man
Re: Can someone please help me
could be a flat lobe maybe a collapsed lifter.seems like you have ruled out all the quick fixes unfortunately you may have to really get your hands dirty.
Old 02-29-2004, 07:35 PM
Thanxz okie-chevy-man that was actually my next thought to take a compression test just wonder if there where any other idea lol.. but i kind of figured not just looken for imput so i thank u very much for ur response
Old 02-29-2004, 10:41 PM
dmilacek dmilacek is offline
Did you replace the plug wires?
Old 03-01-2004, 08:18 PM
yes i replace it all did a tune up already
Old 03-01-2004, 11:17 PM
desertmike1 desertmike1 is offline
If your problem is intermittent you can rule out all internal engine stuff except valves and guides!
Unless your problem reapears at high RPM in en-which case maybe a broken piston ring.
Also you might try strobbing your ignition wires (all 8) with an inductive clip timing light, this will show you an intermittent ignition problem, keep in mind a bad or fouled plug will give you the same indication, take your time.
This could be a simple sticking valve!
-Mike
