Old 09-02-2002, 04:23 PM
dx_tuner's Avatar
dx_tuner dx_tuner is offline
Talking D15B2 build up
What mods can be done to the D15B2 to hang with or beat an SI?
1989 Honda Civic HB DOHC VTEC 1.8L 07 2005
WWW.HONDA-TECH.COM
Old 09-02-2002, 04:28 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
good luck!!!! hehehe
no really a si head will bolt on with a si distribtor,intake, and ecu. you will need to add four wires to the distribtor. but thats it, its a cheap mod and you all keep up with si because your lighter to start with.
Old 09-02-2002, 04:31 PM
dx_tuner's Avatar
I now about the Si head swap and the mini me VTEC but just keeping the dual point fuel injection what mods would it take to beat a 99 SI?
WWW.HONDA-TECH.COM
Old 09-02-2002, 04:35 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
a turbo...spend a grand make a custom turbo, I hear that with such a low compression it can be a good idea and can be set around 10psi with stock internals...haha, maybe its a little outta your budget
blah
Old 09-02-2002, 04:36 PM
Cjz89civic's Avatar
AF Premium User
DUDE go Nos cheapest thing your goin to get to beat that...60 shot hmm feeling brave go 75 but ya goin to need a motor soon if ya go that direction.
Old 09-02-2002, 11:07 PM
dx_tuner's Avatar
a turbo is not out of my budget, I just want to keep it all motor and be able to stomp an SI with a little D15B2 and I may use nitrous(nitrous is not dangerous to the motor only the person that doesn't know how to install it or use it, thats why people say nitrous is not safe ), but I also want to see how much knowledge everyone on this site has. Any more opinions?????????????
WWW.HONDA-TECH.COM
Old 09-02-2002, 11:10 PM
GTA's Avatar
GTA GTA is offline
Whee..
I would like to know....I think nitrous would help it achieve that. Maybe a new cam also. Other than that, not much else i can think of right now.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 09-02-2002, 11:12 PM
dx_tuner's Avatar
what about a ZC tranny
WWW.HONDA-TECH.COM
Old 09-02-2002, 11:14 PM
GTA's Avatar
GTA GTA is offline
Whee..
Yea that would help, either one of those or a SI tranny...i dont remember which is more of a close ratio...
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Sounds like a waste of money to me... If you build a D15b2 to beat a stock Si, it's still only beating a stock Si. There's alot of things you could do, but I think in the end, the ammount of money you'll have to spend to wring a bunch of HP out of a DX is going to far exceed what it would take to just do a motor swap. Unless you go the N20 direction, but if you're planning on a 100 shot, you still need to build the block to handle it.
Old 09-02-2002, 11:17 PM
91zc 91zc is offline
Well if you want to stay all motor:
New cam
Headwork
Higher compression
They key for the d15b2 is fuel. It only uses two fuel injectors so you are going to have to be careful how high the compression is or how much nitrous you squeeze if you are going that route.
Good Luck
91 civic 4dr
b16a
14.8@94
Old 09-02-2002, 11:19 PM
habib_88's Avatar
habib_88 habib_88 is offline
Talking Best D15 mods i've ever seen...
I so love this site hehe
http://www.homemadeturbo.com/dxturbo.html
AND
http://www.homemadeturbo.com/88dx.html
hehe that should give you some ideas if you're really that gun-ho about using your 1.5
89 Si #77 and now with 2003 STS winnAr mod!
LadyNRedSi: the integra is a spotless cow
habibswd: i'd sooooo milk a spotless cow
...wow that was a old conversation
Old 09-02-2002, 11:20 PM
dx_tuner's Avatar
the ZC tranny has a lower gear ratio but combined with the SI final drive gear, it makes a nice quick tranny. And yes I was thinking of doing a motor swap maybe a ZC, cause I can transfer the intake, header to that motor I would just have to grind the header to make the ports a little bigger. But I just want to see how quick I can make the D15B2 but eventually I will go with the ZC. Does APEXi make a header for the 4th gen Civics??
WWW.HONDA-TECH.COM
Old 09-03-2002, 01:20 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
why waste all that money just so you can say i beat you with the stock d15 motor when he can go get an intake system and beat you or whatever else the case is, in the end if you spend all that money on that engine i think your gonna kick yourself in the ass for doing it
2002 Acura TL Type S
1991 Honda Crx Si
Old 09-03-2002, 03:06 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
get a bullfrog head, higher comp ratio. 92hp then 32 hp from the bull frog head so now at 124hp. then get some pistons to 11:5 comp ratio. so now youre at like 150hp, then basic bolt ons so now your at like at 160 fhp. that would spank an si and you would run like low 15s or maybe even high 14s
Jdm D15B2 MPFI VTEC swap on a 88 crx D15b2 DPFI...HELP!! jhmcrx Let's get Technical! 1 11-02-2004 06:09 PM
D15B2 DPFI to JDM D15B2 VTEC MPFI on an 88 crx...i need some help! jhmcrx '88 - '91 Civic | CRX | Wagon | Shuttlee 6 11-01-2004 12:49 AM
d15b2 worth building up or a POS???? Crxce '88 - '91 Civic | CRX | Wagon | Shuttlee 24 08-04-2004 01:24 AM
Bad starting D15B2 diegoaccord '71-'87 Civic | CRX 2 02-22-2002 01:45 AM
