Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-31-2004, 01:03 PM
jhmcrx's Avatar
jhmcrx jhmcrx is offline
Question Jdm D15B2 MPFI VTEC swap on a 88 crx D15b2 DPFI...HELP!!
ok i purchased a jdm d15b2 mpfi vtec motor from a 92-95 civic and i am swaping it on my 88 crx d15b2 DPFI and need to change all of the wiring...
im not 100% sure on what i need to do this, (im confuesed )
im assuiming i need a 92-95 engine wiring harness, 92-95 undash ecu harness, vtec ecu, cluster, downpipe, fuel pump, injector resistor box.. is this right?? i would really appreciate your help.. my car is on jack stands and both motors are on the ground right now can't wait to get it running agian!
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
STD manifold W/adaptor plate
dsm bov
stealthemodeperformance.com oil line's
Tsudo cat back
basic hi flow cat
front tower bar, rear tie bar
short throw shifter
and other small stuff
Old 11-02-2004, 05:09 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you need the engine harness so you can use the plugs, you need to get a obd0 to ob1 conserion harness, need a vtec obd1 ecu a p28 would do, and a header for it. thats all you should need
Team Lonely Drivers
