Old 01-31-2003, 07:38 PM
Crxce Crxce is offline
Send a message via AIM to Crxce
d15b2 worth building up or a POS????
I got a d15b2 in my car and im thinking about swapping it with a b16, and i know the b16 is way better but if i freshen up my engine now can i pull decent horses out of it or is that engine just not worth it????? thank for your help
Old 01-31-2003, 07:41 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
its a good motor for a starter car, i still have my D15B2, 92 or 93 horses its decent and a fun motor for a lil while. u can beat old Jettas with it hehe but its not really too worth it to try and make it into a high performance engine, if u wanna keep it stock then go ahead and freshen it up and rebuild it... if u have the money, do a swap
Old 01-31-2003, 07:42 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
you can build up internals and boost quite high, the compression is only 8.9, which is good for turbos heh, plus mpfi of course
blah
Old 01-31-2003, 07:43 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
Depends on what you're trying to accomplish...If you build the D15b2 right, I'm sure it'll pull good numbers for you, but the only drawback, you're already maxed out at maybe 175 hp (all motor) and the B16 is just getting started.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 01-31-2003, 07:44 PM
1PhatCX's Avatar
again i forgot about the whole mpfi thing... i gotta do that someday to mine hehe
Old 01-31-2003, 07:49 PM
thanks for your help guys i think ill just swap it fuck it, starting off at 160 hp sounds alot bbetter than building up to the max of 160 hp
thats just a waist of cash thanks for your help
Old 01-31-2003, 08:00 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i have to disagree with you. that isn't what the b16 gets to the wheels. a b16 is like 135 to the wheels. dropshop's zc was getting 178 to the wheels at 10 psi (vafc controlled). now he's running hondata and it's at 190whp. the vafc route can be done for $1500 or less
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-31-2003, 08:05 PM
tbk49's Avatar
nniiiiice haha goddamn, zc's seem to be the perfect turbo application, straight swap and not too expensive :sun:
blah
Old 01-31-2003, 08:10 PM
amy@af's Avatar
some numbers.....
b16 + tranny $1600
motor mounts $400
total = $2000
_____________________
ZC or soch vtec $250-500
ecu $150
wiring harness $150
total = $550-$800
turbo = $1500
i'm not hating on the b series. just thought i'd offer a suggestion of another possible route
Old 02-01-2003, 12:37 AM
crxfanatic_88 crxfanatic_88 is offline
Send a message via AIM to crxfanatic_88
I think you could do alot with it. It might take some time and some effort but you can pull it off with the right gear if you know what i mean, almost any car can have potential if you give it some if you know what i mean. I think its worth fixing up, buying the b16 would make it faster but it wuld cost so much money to swap engines.
Old 02-03-2003, 12:18 PM
build it
You can easily make it into an Si. Get an Si injection, and head, possibly a tranny, and you will be running a couple of tenths faster than the Si's stock, and your car will weigh less. If you do that stuff, you should build on to the motor from there, and it would be pretty fast, but like everyone else is sayign a b16 is a good engine for the car, so if you have the money get the swap. But you can get those parts from a junkyard or somewhere for pretty cheap(Si parts that is).
Old 02-03-2003, 12:25 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
you can put about 190 to the wheels...cool...can you do it with a sohc zc?? what kind of turbo?? very very intrested in this b/c i need more power out of my 70hp std...it's lonely and the bottom
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 02-03-2003, 12:40 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I was reading something on Honda-Tech about D15B2s. They are actually an amazing engine when you know what you are doing. They have a near perfect r/s ratio. With certain pistons (I think 1G Integra ones or something) it gives it a nice compression ratio and good power boost. With MPFI it should be just as good if not better than a D16A6 if you put those parts inside it.
I was thinking of swapping engines B16A is a great engine but just too much work in my opinion. I like things that bolt right up so when I do a swap I'm going ZC and probably boost it eventually.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 02-03-2003, 01:06 PM
BLU CIVIC's Avatar
調整器
AMI...CAN YOU GIVE ME MORE INFO ON DROPSHOP'S ZC.....SUX WHEN YOU FEEL A BIG POWER LOSS WHEN YOU HAVE A PASSENGER IN THE CAR...
The name's Adrian
2011 CR-Z - Stock
Old 02-03-2003, 01:32 PM
tbk49's Avatar
a guy in calgary has a d15 turbo, he beat my friend in his 2001 prelude which dynoed at 173whp by about 2 car lengths and the guy in the prelude runs 15.5's...makes me wonder? im not even joking either cause I saw it
for the non beleivers heres a pic, the guy has either mpfi or its the d15 from the 92-95 civic im not sure which?
blah
