Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-25-2002, 07:55 PM
89Max 89Max is offline
brake pedal problem
when I am stopped, my brake pedal keeps pushing toward the floor, until I have the brake on the floor! Sometimes, the car creeps a little (not fully stopped), so much that I have to put the car in neutral, just to stay still. if I pick my foot up, then press the brakes, it does it again. does anyone, or has anyone ever had this problem? it's not my brakes, it's the pedal... i don't know what to do!
Old 08-25-2002, 08:56 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
when last time u had new pads put on? or is u still have ur foot on gas too or ur rpms running high?
Old 08-26-2002, 09:19 AM
I had my whole brake system replaced last year, and new brakes put on the front about a month ago, when I started noticing the problem, the back ones were good, but they cleaned them for me. I'm thinking, is there some sort of hydraulic system in the pedal itself?
Old 08-26-2002, 09:47 AM
NJMAXSELTD NJMAXSELTD is offline
You either have a leak, but by now you'd have run out of fluid and have no brakes at all or (and I'm pretty positive) YOU NEED A NEW MASTER CYLINDER.
Please have this fixed ASAP! We don't want to see a post regarding a front end crash shortly.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 08-26-2002, 08:58 PM
Ravq Ravq is offline
I'm assuming your brake fluid level is ok but I agree with NJMAX... sounds like a failing master cylinder. Please get it checked/fixed immediately.
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
Old 08-27-2002, 12:23 PM
I was checking out my manuel last night, and it may be the "brake booster". it said to pump my brakes a few times, and turn the car on and off. it seemed to help, but we'll see. i will definately get it checked out soon by a professional. thank you for your help!!!
Old 09-25-2002, 09:59 PM
jbling jbling is offline
HAVE U DONE ANYTHING TO YOUR BRAKE SYSTEM LIKE TAKE IT APART OR ANYTHING LIKE THAT? MY GUESS IS THAT YOU GOT AIR IN YOUR BRAKE FLUID VALVE LINE WHICH WILL CAUSE THE BRAKES TO FEEL SPONGY WHEN PRESSING DOWN ON THEM. TO FIX THAT IS VERY EASY, ALL YOU HAVE TO DO IS BLEED THE BRAKES.
~jon
Brake pedal does not return bhw33191 Caprice 8 08-29-2009 10:06 PM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
Brake pedal problem kingcarm 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 19 10-26-2004 07:39 PM
87 Accord Brake Pedal Problem Robin70 Accord/TSX/Accord Hybrid 2 06-17-2002 07:11 PM
