Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-22-2004, 05:07 PM
kingcarm kingcarm is offline
Brake pedal problem
I just noticed that when I press on my brake pedal it seems "squishy". THe brake pedal is pressing farther down to the floor and brakes are ingaging slower because of this. If I pump the brake pedal the brake pedal becomes stiffer and working the way it should but the next time I apply the brakes it is squishy again and pedal pushes further down. What the hell is the problem??? Fluid is right to the full line. NO leaks. If anyone has any ideas I would appreciate it. Thanks.
Carm
My 1991 240SX SE
Old 10-22-2004, 05:12 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Theres either air in the lines or the fluid is just old and shitty. either way flushing the system will cure it.
Old 10-22-2004, 05:49 PM
RedFC3S's Avatar
RedFC3S RedFC3S is offline
Re: Brake pedal problem
just try bleeding the brakes, its easy
1990 RX-7 Turbo II, Streetport, 62-1 Ball Bearing Turbo, FMIC, R.E. Amemiya exhaust, Haltech E6K, GReddy gauges, Apex-i AVC-R, and much much more
Under a complete Time Attack/Drift makeover
Old 10-22-2004, 06:06 PM
Thanks guys. I know you guys know your shit and I appreciate the help. I was thinking about getting braided brake lines so I guess I'll flush the brake system and put new fluid in anyways. Anyone ever install these braided brake lines? Anything I should know or procedure I should follow?
Carm
My 1991 240SX SE
Old 10-22-2004, 08:55 PM
rps13freak's Avatar
rps13freak rps13freak is offline
Originally Posted by kingcarm
brakes are ingaging shower
holy shit your brakes engage a shower. thats badass. tehe
Thats one sexy car!
1989 nissan 240sx
Old 10-22-2004, 09:29 PM
Bryants95240sx's Avatar
Bryants95240sx Bryants95240sx is offline
Send a message via AIM to Bryants95240sx
putting the SB lines are pretty easy just be careful about rounding the head off of the stock lines b/c they have been on there a while
See ya....
Old 10-22-2004, 09:46 PM
Re: Re: Brake pedal problem
oops..........fixed it......thanks.
Carm
My 1991 240SX SE
Old 10-23-2004, 02:54 AM
Tougeman Tougeman is offline
Banned
That sounds like the same thing that happened to my accord... a o-ring or something went bad in the master brake cylender and I had to get a new one..so u could have same prob..
When i went to stop at a stoplight..i could push the pedal say halfway down and hten the car would stop..but a few second later it would start rollling forward and i would have to apply more brake pressure..
Old 10-23-2004, 04:36 PM
Brakes are worst today than yesterday. Brake Pedal goes right to the floor every time I press on it. Brakes ingage when pedal is right to the floor at the last second. Is this still a sign that my brake lines need to be bleed or possibly something else???
Carm
My 1991 240SX SE
Old 10-23-2004, 10:51 PM
Partizan's Avatar
Partizan Partizan is offline
I would try the steel braided hoses, it's a good upgrade anyway and if it fixes it it was most likely a leak in the line.
Old 10-25-2004, 01:58 PM
Banned
master brake cyclinder needs to be replaced
Old 10-25-2004, 06:06 PM
Are you sure??? Is this difficult to change the master brake cylinder?
Carm
My 1991 240SX SE
Old 10-25-2004, 06:46 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
no, do u have ABS? it is easy anyways. disconnect the lines remove the cilinder and replace it. make sure u bleed the fardest line and work ur way to the closest. ( rear right, rear left, front right, and finally front left!!!) (the master cilinder is the thing were the break resevouar rest on. u will get a new one with it. make sur u change it !!!!! u neeeed to stop!!! easy job man!!
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 10-25-2004, 06:51 PM
Yes it has ABS. THat sounds pretty simple. Thanks.
Carm
My 1991 240SX SE
Old 10-26-2004, 05:15 PM
OK....just called Advanced Auto Parts and they quoted me $58.88 plus my shot Master Brake Cylinder for a new (or rebuilt??) Master Cylinder so I'm going to go with that. I went on the Nissan Parts web site and they wanted almost $200. Forget that!!! Thanks for the help guys!!!
Carm
My 1991 240SX SE
