Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-27-2009, 11:49 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Brake pedal does not return
Just replaced my brake pads today. I've been having trouble with my brake pedal for a while though. For about 6 months now when i press on the brake it makes a sort of squeaky noise and feels crunchy, the car still stops fine though. It feels and sounds like a rubber diaphragm that is (suppose) to push the pedal back but i'm not sure. And now today its a lot slower coming back than normal after i replaced my brake pads. So what could this be?
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 08-28-2009, 12:12 AM
inafogg inafogg is offline
Re: Brake pedal does not return
1st thought was master cyl. have you lost fluid,does it hold foot pressure is it possible we got air in the system?? but with the noise your hearing it might be a brake booster thats starting to leak.find the area of the air noise is it down by your feet? ck to make sure hydrolics are ok can you pump up the pedal? good luck,mike
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 08-28-2009, 12:17 AM
buy the wy what year is the car,what was done to the brakes,& is the rest of the system(that you did'nt repair) OK???
Live For Today
Yesterday is gone,
Old 08-28-2009, 08:02 AM
bhw33191's Avatar
The car is an 83. Only brake work i've done is replaced the pads front and rear, did the rear pads a while ago. I need to redo some brake lines so i'll end up bleeding the system then obviously if thats part of the problem right now. And yes the noise is only coming from down near my feet. I hope this isn't expensive to fix or anything.
Old 08-28-2009, 11:10 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Does your engine run rough or experience 'behavior changes' when you press on the brake pedal?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-28-2009, 06:37 PM
j cAT j cAT is offline
if the brake pedal is hard to push down,,,and makes a noise with the engine idle changing this would mean a bad brake booster,,,not too expensive...
if the pedal is soft goes to the floor this is usually a brake line leaking,,,or a bad master cylinder...
when replacing the brake pads it is best to open bleed screw when pushing pads/caliper piston fully back with a C clamp this is to prevent bad brake fliud from entering the master cylinder,,which is not good..
Old 08-28-2009, 09:14 PM
bhw33191's Avatar
I have experienced no changes in the engine behavior when pressing the brake. So i'm not really sure what it could be other than maybe some O-rings or a diaphragm thats dried out..i'll have to take a look tomorrow. I'll have to see if i still have this issue after i replace some well overdue brake lines and bleed the system.
Old 08-29-2009, 10:26 AM
with this info it is most likely the master cylinder needs replacing...if someone placed the wrong fluid into the brake fill container,,,the rubber parts will swell causing this problem....
example would be using a container that had oil in it then using the same container to fill the brake fluid level..
Old 08-29-2009, 10:06 PM
Blue Bowtie's Avatar
Registered Offender
I'm not sure when it started, but my '85 Caprice had HydroBoost instead of a vacuum booster for the brakes. Just a thought.
Tags
brake , pedal , return
