Old 08-09-2002, 02:57 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Need Help Replacing an Axle
I already have my axle, new tranny fluid, and my trusty Helms Manual. I've read through the proceedure, and it doesn't sound difficult. My problem is that the manual says I need to "separate the lower arm from the knuckle using a puller with the pawls applied to the lower arm". Now, I don't have a puller, and I was wondering if there was a way to separate the lower arm without having to use a puller?
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 08-09-2002, 04:08 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
i used a puller, i didnt have one i went out and got one it wasent that expensive but it was kinda wierd using it, it took acouple times to get it right, after you get that off its not that difficult, do you already have the wheel spindle nut off?
2002 Acura TL Type S
1991 Honda Crx Si
Old 08-09-2002, 04:37 PM
Marc-OS's Avatar
I haven't started replacing the axle yet 'cause I wanted to make sure I had everything I need to do the project, but it sounds like I should go buy a puller.
20 GOTO 10
RUN
Old 08-09-2002, 04:38 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
yea, that spindle nut is a BITCH if you access to pnumatic tools USE them, it is a thousions times easyer! i broke a snapon crecent wrench in half while using a breaker bar to get the spindle nut off!
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 08-09-2002, 10:11 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
i changed my axels when doing my swap....and i didnt use any more tools than a rachet and an open ended wrench.....
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 08-10-2002, 01:00 AM
how did you get lower arm off then? and you needed to pull away a pin in it so you must have used pliers or something to grip it with...........
1991 Honda Crx Si
Old 08-10-2002, 06:02 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
i done just always used me a night 5 foot lenght of rebar to seperate the assembly... hehe just be carful it doesn't slip woo wee can that be bad...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 08-10-2002, 09:43 PM
OK i unbolted the top A arm, and the hub nut. then podded the axels out of the tranny (oops i guess i used a crow bar also) then pulled the other side of the axel out of the hub and then wiggled it out away form the car.....
Old 08-11-2002, 04:02 PM
i just replaced my left axle, wasent that hard the 2nd time around well first for this side but whatever, i broke the puller so i went out and get a 5 ton puller that worked gooood
1991 Honda Crx Si
This is really bad, and i really need help..cv-axle is dis-connected. foon Blazer 6 06-20-2006 09:09 AM
need help with axles from s13 turbo N-sAiN 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 02-07-2005 07:30 PM
need help replacing stock w/ coilovers Hmoob Engineering/ Technical 5 03-01-2004 05:40 PM
need help replacing part michiru_umi Aspire 2 11-11-2003 10:09 PM
Need Help, replacing tweeters, how do you get the door panel off? tgunnerson Integra 2 07-22-2002 01:02 PM
