Old 10-24-2003, 10:34 AM
Hmoob Hmoob is offline
Angry need help replacing stock w/ coilovers
Can someone tell me how to get the stock springs out of 93 accord and replace it w/ coilovers?? I dont want to take it to a shop because it will cost alot and i want to actuallie learn how to do it myself. Saves tons. Anyone with knowledge or set of instructions on how to replace stock springs w/ coilover ----please help me.
93 accord lx---replacing all stock springs w/ coilovers.
Can i also swap my 93 accord sohc 2.2L with a 2.2L JDM dohc???
Rims: is it better to go with just 1" above the stock rims to have better control???
Another problem: when i make a right turn of left turn, there's a noise coming from the engine--sounds like 2 rubbers rubbing each other. At any speed---the noise comes on and off when making a turn. Could it be that the steering wheel has a loose bolt or what's happening in there???
THanks to those who respond---
Hmoob
Old 10-25-2003, 07:45 PM
BullShifter's Avatar
Re: need help replacing stock w/ coilovers
Get yourself a repair manual from www.helminc.com & you will also need a spring compressor. The job is pretty easy if not bolts are seized. Check all of your suspension bushings
Old 02-07-2004, 09:40 PM
<[4gen91CvcLX]>'s Avatar
<[4gen91CvcLX]> <[4gen91CvcLX]> is offline
Send a message via AIM to <[4gen91CvcLX]>
1st of all, i would suggest a helms manual to anybody with a car..lol..
2nd...the turning thing sounds like your cv joints might be going bad, does it sound like clicking? bad cv joints are caused by accelerating quickly while turning
3rd....rim sizes are how however big you want them, if you ask, you'll get a million different opinions to go on, but like with everything, the best opinion you should take is one you decide on your own....
good luck w/ everything with you car, and ever need anything dont be afraid to ask...thanks
__________________________________
1997 Honda Civic CX Hatch
Old 02-09-2004, 01:21 PM
civicrunner civicrunner is offline
Make sure u measure your drop and everything correctly...when using coilovers u need to measure and reameasure when putting them on...I put some on my civic...big pain...much easier to go with springs. Like they said get a manual...I used Chiltons and it helped me out ALOT!
Old 02-29-2004, 05:57 AM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
yea, i'm debating whether if i should put my coilovers on or not. Putting them on stock shocks will blow them, so i was thinking bout saving up money for KYB's or Koni Yellow shocks.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 03-01-2004, 05:40 PM
Re: Re: need help replacing stock w/ coilovers
Don't bother with coilover sleeves, either spend the money & get the real thing or stick with aftermarket struts & normal non-adjustable lowering springs.
need help with stock 94 ls sterio ryval124 Integra 1 03-12-2006 11:07 PM
Need help with stock speakers in durango cstradling24 Durango 6 03-01-2006 08:55 PM
Need help on stock 95 1.5 sohc Civic temp no start situation... importvic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 10-06-2005 04:47 PM
need help w/ stock cassette/radio thre3kgt811 3000GT/Stealth 1 03-30-2004 02:03 PM
need help modifying stock headlamps xplode Accord/TSX/Accord Hybrid 1 06-18-2003 11:39 PM
