Old 06-26-2006, 01:27 PM
CeeElle's Avatar
CeeElle CeeElle is offline
wax body before or after decalling?
I did a quick search of the FAQ and how to, then did a search of the keyword "wax" and didn't find an answer. If this question has been asked and answered, please forgive me and send me to the correct thread.
In any event...
Should I apply decals before or after waxing the body of my kit? I've painted and polished the body but do not know where to go from here...
Any help appreciated.
Thanks!
Old 06-26-2006, 04:36 PM
M1CRO M1CRO is offline
Send a message via MSN to M1CRO
Re: wax body before or after decalling?
Most often it is customary to apply primer followed by paint followed by decals followed by laquer THEN lastly,wax. ..Although you might find that some will laquer then apply decals then laquer again to protect the decals.After that you should finish off with light polishing and waxing.This is basically the process I follow..
It is possible to break/crack decals with a Wax, This is probably why a laquer is used.
Hope this helps.
M1CRO.
Old 06-26-2006, 04:41 PM
Vric's Avatar
Vric Vric is offline
If you don't clear coat your decals: wax and then apply decals.
Try to use some MicroSet to clear the place where you will apply the decals. (mix of vinegar and watter do the same thing)
Old 06-26-2006, 05:53 PM
Spitfire7's Avatar
Spitfire7 Spitfire7 is offline
I've had good results by waxing after decals, without using clearcoat. It might be affected by the type of wax - I was using Tamiya wax.
Old 06-27-2006, 05:21 AM
cyberkid's Avatar
cyberkid cyberkid is offline
This kind of sounds wierd, becuase you are waxing the full model then washing the wax off with microset or vinegar.
I asked this question a while back and the best answer I got was to wax AFTER decaling. Reason: wax isn't permanent, it rubs/wears off.
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 06-27-2006, 07:40 AM
Technoman's Avatar
Technoman Technoman is offline
If I am not clearcoating after decalling then I wax after I have put the decals on. I paint the body, polish it, apply decals, then lightly wax with Tamiya wax. The Tamiya wax is very liquid and has no abrasive qualities so it does not affect the decals in any way.
Not so recently completed, I will get another done soon...:
  1. Fiat 131 Rally - ESCI Sponsor
  2. Taisan Starcard 911 GT2
  3. Zexel Skyline R32 GT-R Gr.N
  4. Sierra Cosworth RS500 ANZ
Old 06-27-2006, 08:06 AM
RallyRaider's Avatar
Zomby Woof
Wax. Just posting OT 'cause I love Spitfire7's new avatar! You have very good taste my friend.
Old 06-27-2006, 08:18 AM
mickbench's Avatar
mickbench mickbench is offline
I asked this qestion ages ago... I was told to decal, let decals dry for a few days, and then wax the decals, as the wax washes off, and decals do not stick to wax too well...
If clearcoating, leave the wax off the decals, clear, and then wax the clear.
Old 06-27-2006, 09:17 AM
Spitfire7's Avatar
Heh, thanks Phil
This makes me realise how each person has there own technique for things like waxing. There isn't one set way to do it, but I can recommended waxing after decals without clearcoating. But I guess you just have to try things for yourself and see what works to find the right method
