Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-28-2002, 03:47 AM
Rein Rein is offline
Send a message via AIM to Rein
Ground Control Problem.
This morning I jacked my car up to adjust the height and I found that the little socket where you put the Hex wrentch bit into was missing, it was just a hole. I can't untighten the lock or whatever it's called so I'm screwed. Is this replaceable? If so, do I just stick it in there again, or how do I do it? I musta just been stupid and forgot to tighten it the last time I adjusted the height.
1998 Audi A4 1.8T
*APR turbo back exhaust
*APR 1.0 bar chip upgrade (+40 hp, 88ft-lbs)
*Axis Seven 18s
Future mods:
*H&R full coilover suspension
*APR Stage III+ Turbo Kit (310 hp, 345 ft lbs)
*Stop Tech Slotted Big Brake Kit
Click here to check out my car on Cardomain.com
Secondary car: Black 1992 Civic Si
"Every man dies. Not every man really lives"
Old 07-28-2002, 10:19 AM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
If it's just the little set screw yes you can replace it. Just go to Morton's True Value or something like that and they should have one for like 2 cents.
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
Pt.2 Problems installing Ground Controls! Pics inside!! LX98Civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 04-04-2002 07:24 AM
Problems installing Ground Controls! Pics inside!! LX98Civic Tires and Wheels 6 04-03-2002 02:50 PM
Problems installing Ground Controls! Pics inside!! LX98Civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 03-31-2002 02:57 PM
Ground Control Install Problem Beige4dr Suspension 10 11-13-2001 08:27 PM
