Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-30-2002, 06:33 PM
LX98Civic's Avatar
LX98Civic LX98Civic is offline
Send a message via Yahoo to LX98Civic
Problems installing Ground Controls! Pics inside!!
Today I tried installing the Ground Controls on my 98 civic and had no luck.
I did get the skunk2 camber kit in within an hour, but after spending 4 hours on the drivers / front side with the GC's I gave up!
Below are pics of during the install and the problem I am having. I am starting to think that I was sent the wrong adapters. The shocks in the picture are Bilstein HD's and the GC's I ordered are suppose to be for the HD's. Take a look:
Let's get the first pic out the way. That is installed upside down? I'm 99.9999% it is. Just had to take a pic since I tried every possible way to install the GC's....
In the next picture I have the GC sleeve angled so you can see the adapter at the bottom. It's about 1/2" thick and will not slide pass the gold piece on the Bilstein's where the metal pipe stops.
Here is a top shot of that 1/2" thick ring I am talking about in the pic above:
Ok, in this next picture you can see just how the 1/2" adapter that is marked in green can only go that far down. But, I believe the adapter should slide down to where the blue arrow is on the Bilstein shock.
You can actually see in the instructions underneath the shock how the arrow is pointing to the shock all the way down to that little rest spot on the shock....
Below is a closer pic to show exactly how the GC was sitting. When some weight from the car was let onto the GC's that 1/2" piece popped right out and the spring was loose....
I did manage to get the skunk2 camber kit installed on both sides though:
This next pic is from the passengers side. I didn't even bother with the springs or shocks on this side, since I had all the problems on the drivers side...
Thanks for any input on this!!
---------------------LX98Civic ---------------- nemesls_2000 ------- civickid77----------------
--- --- --- -- Sleeper in the middle -- --- --- ---
Old 03-31-2002, 10:53 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
that's only how far it's supposed to go down on the shock. I have mine installed the same way you were saying it was upside down and mine rides fine so i dont know...if it is wrong then i dont know and i guess i should reverse it. Sorry....i dont know if i was much help.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 04-01-2002, 09:10 AM
LX98Civic's Avatar
Actually, that is the right way in the pic that I say "upside down?". IT's just that it's suppose to sit at the bottom of the shock. Someone photoshopped a pic to show how it is suppose to fit....
See, that is how and where it's suppose to sit:
Old 04-02-2002, 04:12 AM
justanothermike's Avatar
justanothermike justanothermike is offline
Send a message via AIM to justanothermike Send a message via Yahoo to justanothermike
i've heard that bilsteins don't work with coilover sleavs. it looks to me like the shock bodies are to FAT!! hows the ride height with the perch all the way at the bottom? its probably at the same setting when the perch is at the top of the sleave on a properly installed sleave.
Old 04-02-2002, 03:44 PM
LX98Civic's Avatar
THe HD's are self sadjusting so there is no perch to adjust. The guys at GC said I have the wrong adapters The new ones should be here tomm :o
Old 04-03-2002, 07:40 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
DOH! I was going to say from the first picture that is sitting too high
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-03-2002, 02:50 PM
LX98Civic's Avatar
....and the new adapters just arrived
