Old 07-21-2002, 02:32 AM
91hondaguy 91hondaguy is offline
ok how to install a CIA ?
Ok , i got a 96 + civic CIA or aftermarket APC intake . for $10 CDN
real Cheap !!! for the only thing it is for a 96 and up civic and i have a
91 civic so , how can i use that then. i think i might need to move the battery , can somebody tell me how to install that.
thank you
i own a 88 yellow CRX
www.northwestshowoff.com
Old 07-21-2002, 11:34 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..two ways you could go about it...the better way is to relocate your battery into the rear...summit sells kits w/ cables and a box, etc... the not so good way is to just unbolt the battery and kinda wedge it in between the rad and the intake...it still sits on the tray and it gets pretty wedged in there.... I did this w/ a custom CAI I made for my old white hatch before I relocated the battery and we did this with eric's charge piping and its working pretty well....
SOLD!
Old 07-21-2002, 01:09 PM
ok
hmmok ,
i installed the intake it took the whole space where the battery used to be, i tried to wedge sume where but can't find ne place so , i put it in teh rear. i used the + cable as my sub speaker wire i had before. now, it lights up in the instrument panel. but i can't start the engine every time i tried to start it a fuse on the wire would go. please tell which wire to use and do i need a fuse or get a high amp fuse.
thank you
2000 GTP - how to re-install harmonic balancer Van2000GTP Grand Prix 1 02-24-2010 06:44 PM
The basics of how electricity works and why you need to solder wires together J-Ri Cavalier 5 04-19-2009 10:56 PM
Whats the best way to install side skirts? Sonic Eclipse Exterior and Wheels 8 04-06-2009 10:51 AM
installing aftermarket cd player jwhite85 General Discussions 3 03-30-2009 10:52 AM
