Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-11-2002, 02:04 PM
Mugen_R's Avatar
Mugen_R Mugen_R is offline
Send a message via AIM to Mugen_R
Turbo Question
Hi, I wanna add a turbo to my 93 GS-R motor but it's really expensive, but my question is this. Would it work if I went and found a turbo from an old surpa, corola etc...(my auto teacher got a turbo from an old supra celica) and buy the intercooler, etc... and put it onto my car.
would it work>????? if I got the tubing right??? would I need some kind of electrical conenctions??? plz help.
thanks
Old 07-11-2002, 03:10 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
yes it would work. all you gotta do is get pipes. as for electric stuff, no need.
Old 07-11-2002, 05:58 PM
SleeperCivic SleeperCivic is offline
Well, you don't HAVE to have electrics, but I do recommend an electronic boost controller from Greddy or Apexi. The Apexi unit is VERY NICE, but expensive!
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 07-11-2002, 07:18 PM
1320B4U 1320B4U is offline
The hardest part to get is the turbo exhaust manifold. You realize you could only run like 5psi of boost do to your high compression ratio, and if you dont already will only be able to run premium gas. As for parts you'll need a bit, it would be a fun project.
1. Turbo manifold (no clue, but new there like $400+)
2. Turbocharger (Ebay $50+)
3. Bigger exhaust (Custom)
4. Fuel pump and/or injectors (Ebay)
5. Apexi AFC or the like (Ebay $200+)
6. Intercooler and piping (Ebay $50+) piping would need to be custom
7. Blow off valve (Ebay $50+)
8. Turbo air intake (Custom)
9. Boost controller (manuals are like $20) (Ebay)
Old 07-12-2002, 02:07 PM
ViGGa2LO ViGGa2LO is offline
Send a message via AIM to ViGGa2LO
I would also look into getting a wastegate with thick flanges
Old 07-12-2002, 02:17 PM
Mugen_R's Avatar
can somebody explain to me what I would need to do to hook it up and get it working???
Would any of these turbos work????
Turbo1
turbo2
turbo3
turbo4
turbo5
does it have to be a specific turbo or can it basically be any except for the Rotary engine ones????
Thanks
Old 07-12-2002, 02:47 PM
GSteg's Avatar
those turbo should work fine...
Old 07-12-2002, 03:15 PM
Mugen_R's Avatar
I called around some Auto wreckers and found some turbos' but my question is,
Would a turbo made for amercian cars work on my integra???
Would the other parts be compatible with what I get???
How much is 5 psi of boost???
Is there any site on the net that explains how to mount it and get it all set up??? and get it working????
sorry to be such questionable, but I wanna find out how to do this cause I love doing and messing around with the engine.
thanks
Old 07-12-2002, 03:23 PM
GSteg's Avatar
a turbo is a turbo. a turbo from a ford 7.3 powerstroke engine can be used in a 1996 honda civic. the only thing you'll need is an exaust manifold. you can find one from revhard for about $500. make sure you get the b-series manifold. if it's too much for you, you can go to a muffler shop and have them custom make one for you.
5psi is about 34.01psi of the atmosphere pressure jk. 5psi is low enough to run on your stock engine. although they could be stuffed with more psi, 5-6 psi is usually the standard boost of many kits. u should be fine with 6psi.
Old 07-12-2002, 03:35 PM
Mugen_R's Avatar
Thanks. But if I would get a ford 7.3 turbo, do I need to get the ford exhaust manifold or do I get the acura one???
Last question:
what kind turbo would you recomend me to get???
Not including the new ones, a turbo that I can get off of basically an autowreckers, but I would like your input on which one would be the BEST to use.
Old 07-12-2002, 03:39 PM
And on a properly set-up turbo system 1psi (pound) should equal about 10-15hp, so 5psi should net a 50-70hp gain.
Old 07-12-2002, 03:42 PM
I would get a small one that because you can't run that much boost and it will give a better spool up = less lag.
Old 07-12-2002, 04:01 PM
Grendel's Avatar
Grendel Grendel is offline
The manifold is basically just a couple tubes that hooks the spot where the exhaust leaves the head to the spot where the exhaust enters the turbo...
You would need to get a manifold made for your motors head, if you took one off the ford engine, it probably wouldn't bolt to your head...
Also, correct me if im wrong guys, but dont turbos from different manufacturers have different shaped/size areas where they bolt to the manifold? He would need to make sure the turbo he gets matches up the the manifold he gets...
-Grendel
Old 07-12-2002, 04:33 PM
Mugen_R's Avatar
What turbo would you guys recomend??? from what car and year.
thanks
Old 07-13-2002, 11:45 AM
GSteg's Avatar
a T3 turbo from some old Saab. they work good enough. get the manifold that is for your engine. theoretically, a T3 should bolt right on to the B-series exaust manifold. if you don't want to risk it, get a muffler shop to make one for you. they will cost less than name brand manifolds. the T3 has quick spool-up times and has the potential to make lots of power, but the price on one is pretty expensive.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1842746174
u can look on ebay and try to find some old porsche, volvo, saab, etc. cars. i was just showing an example of the ford 7.3 turbo how they can be used in a civic, etc. i didn't mean its the best one to go cuz the time it takes to spin one of those things is forever (you'll need lots of power in order to do so)
Stupid turbo question? Do a CT 26 turbo need a gasket seal or seal? DrifterRZero MR2/MR-S 2 11-19-2010 02:52 AM
Tranny questions and turbo questions... Marc-OS 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 05-08-2004 01:40 AM
Turbo Question criscross79 Impreza/9-2x/Outback Sport 8 01-28-2002 04:47 PM
Turbo question Initial_E 911 4 12-28-2001 06:51 PM
Turbo question? MDurs Engine 3 12-05-2001 06:36 PM
