Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 10-19-2010, 04:18 PM
DrifterRZero DrifterRZero is offline
Stupid turbo question? Do a CT 26 turbo need a gasket seal or seal?
I got a question regarding installing a turbo. I recently got myself a rebuilt CT26 turbo for my MR2 and the fact that this is my first turbo car. Are you supposed to just bolt the turbo on without a gasket seal or a seal to the engine?
I been googleing the question on the internet and vague at best. So far I heard is that you basically don't need to because the surface where the turbo suppose to mated to are both flat surface?? this true or rather is it true on most turbo cars?
I saw the other guy's thread asking a turbo question, but I didn't want to be rude in posingt a question in that guy thread
Old 11-09-2010, 11:00 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Stupid turbo question? Do a CT 26 turbo need a gasket seal or seal?
It may look flat, but it's not milled flat. You should use a crushable metal flange gasket to acccount for any slight waviness between the surfaces. They usually look like layered aluminum or soft copper stamped out of a sheet.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-19-2010, 03:52 AM
cbulen cbulen is offline
Yes, you have to have a turbo gasket between the manifold and the turbo, and between the turbo and the turbo elbow (or downpipe if you are running a downpipe).
There is also a gasket between the the oil/water pipe the the turbo. DOn't bend the oil returns/water pipe, whatever you do!
Good idea to replace this pipe if yours has a lot of miles on it.
______
CBulen
My V8 swap into a 1991 and 1993 Toyota MR2
Project MV8R
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 09:29 AM
Oil Pan Gasket- cork gasket or seal packing - or both? floridacamry Camry/Camry Hybrid/Vista 4 09-06-2009 10:47 AM
Kinda stupid turbo question david-b Bolt on Parts 6 03-15-2008 01:31 AM
Cam seal, crank seal, water pump questions f100240 Metro 6 12-17-2007 04:24 AM
stupid question but need to know Masked Shadow '94 - '01 3 07-04-2005 12:11 AM
