Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-07-2002, 10:27 PM
taeMaX97 taeMaX97 is offline
Unhappy y-pipe question....need help~~
i just had my Budget y-pipe installed couple days ago. and next day when i driving it BATTERY and BRAKE LIGHT came on. and i was just reading through some instruction on installing it and saw this.......
SPECIAL NOTE: If you have extra $$ lying around, why not change out your old o2 sensors? REMEMBER, after you're done installing the ypipe. Besure to remove one terminal to the battery to RESET your ecu..
you guys think this is the reason why those light came on???? i don't know what to do. i need you guys to help me out.... what can be done? and how is it suppose to sound like?? right now it sounds like 80 camaro at low rpm and it gets lil quiter at higher rpm. i have budget y-pipe and apexi dunk muffler with resonator taken out. THANKS~
Old 07-08-2002, 02:44 AM
mtrai760 mtrai760 is offline
Send a message via AIM to mtrai760
Did you put it in yourself? Make sure the negative and positive battery terminal's are tightned down, and look for any loose wires, if you can't find anything, take it back to the place that installed it, and tell them they messed up your car! BTW, I wouldn't drive with the brake light on, you may have a problem with the car, unless you have ABS, then you may just have a problem with your charging system or loose terminal...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
Apexi N1 good? and piping question Prelude707 Prelude 15 02-24-2004 07:26 PM
Tuned Pipe Question jaxson Remote Control Cars 15 08-26-2003 02:45 PM
Turbo piping question. doug294 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 08-21-2003 01:35 PM
custom piping question elitethug '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 22 02-12-2003 04:03 PM
Custom Piping Question changedagame108 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 01-29-2002 08:33 AM
