Old 07-07-2002, 05:47 PM
Phat_Si's Avatar
Phat_Si Phat_Si is offline
Send a message via AIM to Phat_Si
Thermostat question!
ok, my car gets hot sometimes, well not really hot, it goes like 3/4 the way up the temp gauge but it stays in the normal range. My boss said that has happened to alot of his cars and he said he just takes out the thermostat and it will keep coolant running throughout the system constently and it will help cool it. Is this true??? he has done it to all of his cars and the temp gauge on his cars stay at 1/4 of it. my question is will taking it out work?
-----'89 Crx Si-----
I/E
NGK plug wires
Custom backseat
Rims
clear corners
Awia head unit w/Pioneer speakers
Blowin' Smoke!
--Soon To Be--
slammed
new D16a6 block
sohc vtec d16z6 head, P&P'ed
gude stage 2 cam
gude cam gear
some fuel goodies etc...
Old 07-07-2002, 05:58 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Temp
I wouldn't take your thermostat out. I would check and see if you fan kicks on. If the fan dosen't kick on than thats probally your problem. The thermostat keeps the car around a certain temperature where the car operates best. I believe Honda keeps their cars around 160 degrees. If you take the thermostat out than the car will take forever to warm up in the cold mornings.
Old 07-07-2002, 08:11 PM
shatshadarach shatshadarach is offline
dont take your thermostat out...just replace it if its broke...not like its expensive...let it idle for about 5 mins after the temp gauge is warm...and touch your upper rad hose, if its hot, then your thermostat is good and youve got other problems...which removing the thermostat will not fix
Old 07-07-2002, 08:16 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea dont remove the thermo, the car runs at a specific temp for a reason, which i wont get into here, unless you want me too, anyway, an easy check for the thermo to be working, is wait till the car is at your normal temperature, then squeeze the upper rad hose, if its solid, then your thermo is good, if its mushy, then u need a new one, they cost about 5 bux. if it turns out good, check to see if you have enough coolant in the system, then check to see if the fan is working.
knock out the most likely problems first b4 you go in depth.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Thermostat Question sunmicroman Metro 2 03-31-2005 03:17 PM
thermostat Questions Volcruz Taurus | Taurus Wagon 5 01-21-2005 03:09 PM
THERMOSTAT question YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 01-16-2005 02:14 PM
general thermostat question zdude 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 7 01-02-2005 11:13 PM
Thermostat Question 240ztt Engine 5 08-01-2001 11:20 PM
