Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 06-02-2002, 04:53 AM
anotherRex anotherRex is offline
How much can I boost my unmodified WRX?
Could anyone tell me how much can I boost my unmodified WRX (not STi version)?
I meant boost and can still safely drive everyday use (not blow away the engine).
I have changed some parts a bit:
1) changed standard turbo to VF22
2) installed UNICHIP and a modify box which currently boost at 14 psi
My target is 17 psi, is it safe to do that?
Old 06-02-2002, 03:17 PM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
Re: How much can I boost my unmodified WRX?
I beleave 17psi is the rated max boost for the stock turbos. I'd play it safe and shoot for 16.5. Perhaps set it up to run 17 for a little bit in a few gears but thats up to you. If it were me I'd target 16.5 psi and wait on a some gasgets, IC, and such, then go for 18 or 19.
Woops, just noticed you upgraded turbo, so I'd say 17 would be OK... Wouldn't go much higher then that with stock internals though just to play it safe and be nice to your engine
Welcome to AF also
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 06-05-2002, 12:52 PM
Super Spec V Super Spec V is offline
RE
I have upgraded the fuel pressure regulator and used 112 octane fuel, and i was able to run 20psi at the track, but not for the whole day.
If you are planning to run 17psi on the street for everyday driving...be careful, because that is alot of boost for an engine that can only run on pump fuel. Get a boost controller with high and low settings, and then set the low for steet, and the high for SUPER STREET.
PS
WELCOME TO AF!!
A Game of chess is like a sword fight. You must think first before you move!
Old 06-11-2002, 09:34 AM
Racing Rice's Avatar
Racing Rice Racing Rice is offline
Send a message via ICQ to Racing Rice Send a message via AIM to Racing Rice
You may also want to get it tuned after turning up the boost to ensure your running at safe levels.
Racing Rice
Cars:
'97 Civic EX, '02 Explorer Eddie Bauer, '99 Isuzu Amigo 4x4
Bikes:
'05 Suzuki DL650 Vstrom, '05 Yamaha Raptor 660R
Old 06-13-2002, 05:36 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Get your A/F ratios checked and remapped at that level. If any probs., upgrade to a bigger (pref. front mount) intercooler.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 06-13-2002, 02:23 PM
Gonthrax's Avatar
Skyline Guy
Mmmm Front mount
Strange, I know 3 ppl with WRXs, and none of them want to switch to a front mount! Of course one of them doesn't want to get an Intake 'cause he wants to do all sorts of other things and is afraid "gettin an intake will make him run to lean"
Neishlin Motors
Old 06-14-2002, 09:03 AM
RE
The REX runs very rich from factory, so i dont thinki that an intake will make him run lean enough that he will notice the difference. If hes worried cause he wants to raise the boost....tell him to use good fuel, and he will be ok.
Old 06-14-2002, 01:41 PM
Gonthrax's Avatar
Skyline Guy
Re: RE
Yea, he already knows it runs rich stock so I don't know why he's worried. Furthermore he wants to get a s-AFC so I don't see what the problem is Right now we are running 16.5 1st, 2nd, 3rd, and 16 on up. (Just 'cause I can't get it to hit 16.5 in 4th and 5th )
Neishlin Motors
Old 07-06-2002, 12:45 AM
rex4ev rex4ev is offline
Send a message via AIM to rex4ev
check out these sites,
http://www.turboxs.com/
http://www.vishnuperformance.com/welcome.htm
the stock injectors cant handle much more than 17psi of boost, your new turbo is probably going to take them to their limits quick, so i would recommend an apexi-afc, exhaust temp gauge, and bigger injectors/upgraded fuel system. this will ensure reliability and keep your engine from detonating.
Old 07-31-2002, 03:19 PM
marks944 marks944 is offline
Send a message via AIM to marks944
We've installed superchips in otherwise stock WRXs and have run them as high as 20 psi without a problem. however, we do set the boost to 16 psi and let the owners go from there.
Old 07-31-2002, 09:52 PM
illracer's Avatar
illracer illracer is offline
Ordinarily I'd say 17 is a bit high for a stock WRX but with an IHI VF22 you should be able to support 17 without much difficulty. Also running higher octane gas will advance the ecu's timing but 112 is a bit high. To be honest I've never seen anything as high as 112 in unleaded. I'd say you should be straight for an even 17 but not that much higher without fuel components or else you'll run into some mad detonation at high rpms.
Old 11-17-2002, 11:20 AM
Shaji Shaji is offline
Send a message via AIM to Shaji
get new fuel injectors before u do anything else for gods sake!!
Shaji
Old 11-17-2002, 01:00 PM
I have done many installs on these beasts, and even with stock turbos, 17 is doable!! Also as far as injectors, the stock injectors work fine at this range. I've installed STI injectors, but only in more highly modified cars! In addition to that, we installed a fuel pump from a Toyota Supra Turbo, to increase fuel delivery. As far as front mount intercoolers, don't waste your money! install a Turbo XS top mount or similar, replace your scoop with an STI, and install a diverter! Then if you want, run your windshield washer pump line to the tomoune, install a spray type washer nozzle, and you have an way to keep the temp of the intercooler down on those warm days! Just remember to switch back in cold weather, and use w/w antifreeze to prevent freezing!!
what is the stock boost on a 98 gst, how much can that be increased without major mod billybob101 Off-Topic 17 06-16-2004 02:15 AM
How much can I boost??? vsiev MR2/MR-S 63 03-15-2004 05:59 AM
How much can 12V hold? NuEra Car Audio 8 08-28-2002 09:05 PM
How much can I boost my standard WRX'96? Jirapun Suspension 2 07-30-2002 10:39 AM
How Much Can I Get? crxlvr Camaro Discussions 1 03-05-2002 01:59 AM
