Old 08-27-2002, 11:52 PM
NuEra's Avatar
NuEra NuEra is offline
Banned
Question How much can 12V hold?
I want to splice something again into my 12V power outlet wire and I'm wondering if its gonna get overloaded. So far I have an RPM switch and a single LED running off it. Now I want to put another single LED and maybe my indiglo gauges. Will this be too much? Is it just the indiglos that might be too much? thanks.
Old 08-28-2002, 12:03 AM
Whitey001 Whitey001 is offline
Depends on the fuse rating from the +12 leg u are coming off of. If its just strait from the battery it should work.:flash:
Old 08-28-2002, 12:07 AM
NuEra's Avatar
Banned
No its not, its literally from the wire in the back of the power outlet.
Old 08-28-2002, 01:41 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
You're typical LED draws about .02 Amps (20mA) which is like nothing... I wouldn't really worry about it.
Old 08-28-2002, 04:07 PM
NuEra's Avatar
Banned
What about the indiglos?
Old 08-28-2002, 04:14 PM
swedish swedish is offline
well, it should say on the box how much power they draw, but even if it doesn't, it should be fine, think about it this way, cell phones, pagers and watches have indiglo, if a watch battery can handle indiglo, there should be no problem for a car, plus indiglo's probably draw the same or even less power than the stock lighting
"One great big festering neon distraction,
I've a suggestion to keep you all occupied.
Learn to swim."
Old 08-28-2002, 04:17 PM
NuEra's Avatar
Banned
OK, but do you think that wire can handle everything?
Old 08-28-2002, 06:00 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
if ur really worried about ur power connections i would get some supplys together and create a new power distribution system 4 all ur gadgets. Like run a new power wire from ur batt. to a fused distribution block and run 1 lead to ur LED's & 1 to ur indiglos & so on, sorta like ur own personal fuse panel.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 08-28-2002, 09:05 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
that's what I did in the rex ..... I put it on a panel behind the glove box, then cut the back of the glovebox out. There are three X 6 place fuse blocks (one for const +12V, switched +12V, and lights) and a barrier strip for the gnd wires. The 12 Sw & the lights use a regualr bosch style relay, so the draw on the cars interior electronics is very minimal.
how long can you hold your breath? dirtydx COMPLETELY off-topic 32 12-30-2004 01:08 PM
how much can fuel pressure regulator hold? silver Mr2 MR2/MR-S 2 10-28-2003 10:52 AM
How much can I boost my unmodified WRX? anotherRex Impreza/9-2x/Outback Sport 12 11-17-2002 01:00 PM
How much can I boost my standard WRX'96? Jirapun Suspension 2 07-30-2002 10:39 AM
How Much Can I Get? crxlvr Camaro Discussions 1 03-05-2002 01:59 AM
