Old 05-27-2002, 10:33 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Rattle Noise?
I just installed my header and they had a hole in the weld, so I fixed it using some "Thermo-Seal" stuff. Well, I got this rattling noise from them somewhere, I pulled the heat shield off my Cat, thinking that this would fix it, but it does not. What else could it be? Anyone have any suggestions? It only happens between 2.5 and 3.2 thousand RPM's when car is in motion (does nopt make this noise when in neutral).
Thanks!
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 05-28-2002, 01:38 AM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
It might be the heat shield farther down your exhaust, did you check those? Mine had a screw loose once and made a horrible sound around that rpm.
Old 05-29-2002, 07:41 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I bet your cat is blown. Mine is making a rattle when I take off from a stop. I got underneith the car and I hit the cat and the rattle is comming from inside the cat. Get under the car and hit the cat.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 05-29-2002, 11:04 PM
thewoahna's Avatar
I just installed a new cat about 3 months ago when I got my DC Catback. I put in a new CATCO High Flow cat, would this be blown already?
AOL IM: WoahNa316
Old 05-29-2002, 11:20 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
another thing to check... less intuitive... if you've got an automatic transmission, make sure you've got enough fluid in it.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 05-30-2002, 08:15 PM
thewoahna's Avatar
That cant be the problem, I have a 5-Speed. It sounds like it is coming from the front somewhere. It is odd because it is only between the first stated RPM's, I dont know if it is something that needs to be fixed or if it is just an annoyance "nothing".
AOL IM: WoahNa316
Old 05-30-2002, 10:28 PM
does it matter whether you're driving or not?
Old 05-31-2002, 12:38 AM
MechanisM MechanisM is offline
I am also having this exact same problem....I just got my exhaust installed and it is doing the exact same thing at the exact same rpms and only while moving.
-Red AEM Shortram---removed
-Polished Injen CAI
-DC Sports 4-2-1 Ceramics
-Thermal R&D Classic Cat-Back
Old 06-01-2002, 12:00 PM
Arrow ..
Ok....while under the car checking to make sure all sheilds and such were tight....I noticed that the brace that holds the downpipe of the header was broken....this is the horseshoe looking bracket. I'm not sure if it is different on other types of Hondas. I took this to a friend and had it spot welded and it cleared up the rattle.
-Polished Injen CAI
Old 06-02-2002, 10:57 PM
thewoahna's Avatar
Yeah, it only makes this noise when I am driving.
AOL IM: WoahNa316
Old 06-04-2002, 09:08 PM
WRXNSX WRXNSX is offline
Yeah I got kinda same prob. here too ..just installed an Apexi WS exhaust but I hear more of squeaking sound at about (3000 rpm). The exhuast is secure so.. any ideas???
Old 09-22-2002, 03:36 AM
strodda strodda is offline
did you ever find out what it was??? same thing happened to me today.
Old 09-23-2002, 01:17 AM
Tominos Tominos is offline
could it be a rock or pebble in the cat shield? i had this problem once, an dtook off the shield and pebble fell out.
Old 09-23-2002, 02:58 AM
i wish it was that easy. i found that i has an exhasut leak between the cat and the backpipe. i fixed it, but still that rattle. its sounds like its coming from the front somewhere. what could cause a noise to occur only when in gear? i could rev it to redline in park/neutral and never hear anything. but as soon as i stick it in 1st and start going, it comes back.
Old 09-23-2002, 02:42 PM
thewoahna's Avatar
I never did find out the problem on mine. I checked all the heat shields and I could not find anything that I think would cause a rattle noise. I have kinda just learned to live with mine, it has gotten a LITTLE better, but not a whole lot. I have heard from people on other forums say that sometimes with the Seramic header, the Ceramic coating on the inside will loosen and sometimes make a noise, but mine have been making a noise since day one, so I dont know if that is the problem or not. I probably should have just gone with Stainless Header.
AOL IM: WoahNa316
2000 3.8 #2 missfire and strange plenum noise and rattling noise possibly cured hatethewindstar Windstar 19 05-28-2012 06:49 PM
95 Geo Prizm Rattling/Knocking mattTc17 Nova | Prizm | Spectrum | Sprint 4 03-28-2010 04:31 PM
Passenger side ticking/rattle noise ktl4974 Problem Diagnosis 9 08-29-2009 09:31 PM
Rattle noise at about 3k - 4k revs?? Integra Si VTEC Integra 7 02-01-2005 02:49 PM
dentist drill like noise & rattling noise 96LSIntegraRocket Integra 2 05-17-2002 12:50 AM
