Old 09-01-2003, 04:01 PM
sheemo3 sheemo3 is offline
Post What is the difference between boring and stroking a motor?
Can anybody help me out? Thanks
Old 09-01-2003, 05:40 PM
boosted331 boosted331 is offline
bore is the diameter of the cylinders, stroke is the length the piston travels in the cylinder. Typically a motor with a longer stroke and a smaller bore won't rev as high as a big bore/small stroke motor, but will produce much more torque on the low end. On the flipside, a big bore, small stroke motor will rev like the dickens but not make much torque.
Old 09-02-2003, 08:39 PM
93hybridaccord 93hybridaccord is offline
In order to bore a motor, you grind away at the cylinder wall. Not much, we are talking like thousandths of an inch. A stroked motor is when you enlarge the lobe on the crank. 2 ways to do this, either buy a larger crank or either you or a shop has to place a weld on the lobes then grind and sand it down til it's clean but a hair larger.
93 accord - jdm h22a
2003 srt-4 - daily driver
Old 09-02-2003, 11:50 PM
S13GTR S13GTR is offline
To make a long story short if you stroke you gain bottom end and loose revability, boring leaves you the same revability and gives improved powerband.
what the difference between pk2 and pk3? tblake Grand Prix 2 08-09-2006 12:15 PM
whats the difference between sr20de and sr20det? GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 10-11-2004 01:10 AM
whats the difference between the ecu and the eprom? BlackShadowTSi Off-Topic 11 06-15-2004 01:23 PM
whats the difference between urathane and fiberglass body kits? rsxballa Integra 3 05-21-2004 06:08 AM
whats the difference between ex and si? 95civsi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 04-05-2004 01:41 PM
