Old 05-07-2002, 12:18 PM
bc4g bc4g is offline
Zc-vs. -sohc Vtec
Ok a lot of people are going with the ZC engine for more power and I dont blame them anything is better than 70 hp. I had planned on going this route too untill I was offered that cheap SOHC VTEC. But my question is why do people do the ZC swap 130 hp when you can get a SOHC VTEC with 125 hp and get a lot more after market parts for it? I now about the HKS cams and the jackson racing supercharger but places like AEM you have to crossrefrence things- I have heard you have to get B-series adj cams and have to machine them to fit for a ZC.
I would just like all the ZC peoples opinoin on it
Thanks
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 05-07-2002, 12:55 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Smile
Why I have a ZC -
1 - I got a good deal on my whole setup for my ZC.
2 - if I ever did choose to tune it, I think it would be a little easier and more precise since it is a DOHC and not SOHC, but I don't really know anything about that stuff yet.
3 - Plus I don't have to ghetto rig an OBD-1 into my non-OBD car. Drop and go!
My $0.02
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 05-07-2002, 03:17 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
people go with the ZC because it costs the absolute bottom line least. the sohc v-tec can cost a couple of $$$ more depending on the route you go.
the sohc v-tec does drop right in...i just did it this weekend. just like the ZC...no rewiring. HOWEVER, i just learned a valuable lesson...getting a wiring harness and using the 92-95 ECU works like sh*t. i ended up sticking my ECU back in and now i'm going to wire up a v-tec controller. it is actually cheaper to go the v-tec controller route.
if you have a DX you will have to do the MPFI swap no matter which swap you do.
here is the reason i decided against a ZC. i tried to order one from several places (including Nippon) and none of them warrenty the ZC anymore. I've heard the b.s. excuse that it's because the ZC won't pass emissions in some states. i say that is b.s because they still warrenty the b16 and it has the same emissions issues. these people just don't want to tell you they don't want to replace anything on the ZC because they know it's gonna break.
don't get me wrong, i have heard good stories about ZC's but not as many as bad.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 05-07-2002, 05:15 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
ZC Emissions
do people really have that much trouble passing emissions with the ZC? I heard that it wasn't that much of an issue, but maybe I'm wrong...
Old 05-07-2002, 05:33 PM
amy@af's Avatar
Re: ZC Emissions
that is why i said "b.s. excuse"
ami
Old 05-07-2002, 08:13 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yeh thats why i didn't choose the ZC cause i've been hearing bad stories on them. Its a good choice if you're on a low budget though. So is the sohc v-tec. If anything i would just choose the sohc v-tec. The ZC and the sohc v-tec specs are almost identical.
Old 05-08-2002, 01:20 AM
awsome info guys and Ami keep me posted I may have bug you a lot when I do mine. Hit me back let me know how its working and who you race.
Thanks
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 05-08-2002, 01:23 AM
Hey Ami what cartoons do you watch?
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 05-08-2002, 05:55 AM
civic1991 civic1991 is offline
Send a message via AIM to civic1991
I just ordered a harness for my stock Si wiring harness that will convert it to OBD-1. There is nothing janky about it, and now I can run the P28 which will allow me to run the right fuel curve to the D16Y8 and let me tack it up to 7500rpm stock.
**DO YOU RACE OR JUST RICE**
What do those Altazzas add, like 15Hp? HAHAHAHAHAHA!!!!!!!!!!!
Old 05-08-2002, 07:53 AM
CWBETB's Avatar
CWBETB CWBETB is offline
Send a message via AIM to CWBETB
Here we go.....
ZC is a 10+ year old engine, this is why you hear people having problems with them. A SOHC Vtec is alot newer and usually do not have as much wear.
A ZC will pass a pipe test but will fail a visual inspection "engine is stamped ZC which is not a US engine"
ZC has more tourque then a soch vtec, this is why alot of people like them. Either way both are pretty close to eachother in the performance factor
90 Turbo/ZC Civic
http://www.myspace.com/cwbetb
Old 05-08-2002, 09:14 AM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
hey- did you guys know that there is a SOHC ZC and a DOHC ZC. i thought it was only a DOHC motor....but my friend did a swap...and he put a SOHC motor in his 88 civic dx hatch....and the engine block said ZC. weird.....i'd never heard of it before...anyways....about the discussion i would say that the DOHC ZC is better for turbo....but the D16z6/y8 is better for bolt ons because of the the huge aftermarket support for the civic ex. you are gonna be doing a lot more searchin for performance parts for the zc.
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 05-08-2002, 10:00 AM
sastanley's Avatar
AF Premium User
Thumbs up
Here is some more info about the different ZC's available..
http://asia.vtec.net/topics/zc.html
-Shawn
'91 Civic DX sedan
Old 05-08-2002, 10:17 AM
CWBETB's Avatar
Nice info Shawn, to bad they dont have anything about the ZCG engine
90 Turbo/ZC Civic
Old 05-08-2002, 11:09 AM
mellowboy's Avatar
Well i thought ZCG is another name for b16a? Thats what i've been told on here when it was PH.
Old 05-08-2002, 11:27 AM
sastanley's Avatar
AF Premium User
Thumbs up
Yeah..that is what I read too..here ==> http://hybrid2.honda-perf.org/tech/engine.html
-Shawn
'91 Civic DX sedan
b16a vs. ZC vs. Sohc Vtec? QuickSilverEF9 '88 - '91 Civic | CRX | Wagon | Shuttlee 68 04-03-2006 02:58 AM
DOHC ZC Vs. SOHC D16 Vtec 99GSR '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-26-2004 09:59 PM
DOHC ZC vs. SOHC VTEC 90civichatch '88 - '91 Civic | CRX | Wagon | Shuttlee 19 04-13-2004 12:05 PM
SOHC ZC vs. DOHC ZC yeha22 '88 - '91 Civic | CRX | Wagon | Shuttlee 13 07-07-2003 03:13 PM
89 Teg. LS swap vs. SOHC VTEC swap cornbread499 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-24-2003 09:21 PM
