Old 07-07-2003, 10:54 AM
yeha22 yeha22 is offline
SOHC ZC vs. DOHC ZC
what are the differences between a single and a dual cam ZC? how much difference is there? how different are they to install? should a DOHC be much harder to install than a SOHC?
thank you in advance.
Old 07-07-2003, 10:57 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: SOHC ZC vs. DOHC ZC
one is DOHC the other is SOHC
No , i think they r about 10bhp difference
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 07-07-2003, 11:31 AM
91civicDXdude's Avatar
the DOHC ZC is rated at 130hp, while the SOHC ZC is the same as the USDM D16A6, which is 108hp.
Old 07-07-2003, 01:00 PM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
i beg to differ ... i will admit that its basicly the same as the d16a6 but i believe it has the higher compression ratio allowing it actually 118hp with MPFI and around 108 with DPFI.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 07-07-2003, 01:09 PM
ok, well here is my problem (i don't care about the horsepower right now). i was quoted a price to install my ZC. my engine got delevired to the shop today, and i got a call saying that they had quoted me for a SOHC install, not a DOHC install. they are going to charge me more to install a DOHC ZC. he said something about needing new intake, new exhaust, etc... is this right? i thought all ZCs were just a straight swap in replacement, right? or am i wrong?
if there is a difference, what extra is involved in installing the DOHC ZC?
Old 07-07-2003, 01:23 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..there is absolutely no difference between installing a dohc or sohc zc...the parts for the swap are exactly the same...
SOLD!
Old 07-07-2003, 01:48 PM
88CRX's Avatar
88CRX 88CRX is offline
tell that shop to stick it and go elsewhere.
zc powa
short ram intake
dc sports header
2.25 Magnaflow exhaust
h/r race springs
Old 07-07-2003, 01:49 PM
D15Bitch's Avatar
D15Bitch D15Bitch is offline
Angry CAN YOU SAY "BASTIDZ".....
Don't believe it. All your existing manifolds should mate up no problem. Besides, the engine should also come with it's own intake and exhaust manifolds. And the amount of labour is exactly the same...
Tell 'em you're getting other quotes...
Old 07-07-2003, 01:54 PM
the parts are the same... so this guy is messing with me. trying to take my money? i should not let him charge me more, right?
Old 07-07-2003, 02:00 PM
ok, just saw the other two posts. thanks guys. i'm about to call the shop back. they can either install it for the price they quoted me, or they can shove it and i will take my engine elsewhere. thanks.
Old 07-07-2003, 02:25 PM
sorry for the multiple posts...
i just talked with the guy at the shop. he says the problem is with the cam sensor and the knock sensor. he says that the Si ECU doesn't have provisions for these sensors, but the ZC needs these sensors. he says that i need a new ECU. is this true? please help.
thanks.
Old 07-07-2003, 02:29 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
you might want to think about taking it to another shop any way b/c that guy has no clue... the zc has no knock sensor and the si does have a cam angle sensor also...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 07-07-2003, 02:33 PM
marked001's Avatar
Moderadur
the cam sensor is outside of the zc dizzy, unlike the si (I think that's it)... the only change here is the repinning of a couple plugs.. simple
SOLD!
Old 07-07-2003, 03:13 PM
D15Bitch's Avatar
Riddle me this...
This guy knows shit. Why is he charging for knock sensors? He quoted you for a ZC SOHC did he not? Does a ZC SOHC have a knock sensor? Not unless I am misinformed...
Pushrod vs. SOHC vs. DOHC beef_bourito Engineering/ Technical 74 03-08-2008 03:46 PM
Motor: SOHC vs DOHC | Need Help!! Rebel02hl '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-13-2004 09:34 PM
SOHC vs. DOHC kenyonblue 3000GT/Stealth 4 03-29-2004 02:36 PM
sohc vs dohc rolnaldo33 Neon | Plymouth Neon 13 02-16-2004 04:09 PM
SOHC vs DOHC friday86 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 17 06-16-2003 01:56 PM
