Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-04-2002, 11:57 PM
gotboost? gotboost? is offline
Send a message via AIM to gotboost?
How Much Boost ??? Turbo Integra
I HAVE A TURBO WAITING FOR ME IN MY ROOM BUT I AM A LITTLE SHORT ON TIME SO I CANT PUT A HIGH PERFORMANCE CLUTCH IN. SO MY Q IS HOW MUCH BOOST CAN I RUN ON IT WITH OUT BURNING OUT MY STOCK CLUTCH ITS A GS-R I WOULD REALY APRICIATE THIS INFO
Old 05-09-2002, 11:37 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
running even 5-6 psi is gonna put a lot of strain on your clutch...is your clutch still in decent shape? Also, the way you drive it is going to have an effect on the clutches life. If you run it hard all the time, dont expect it to last long...but if you only get on it once in a while, it might go a little longer before slipping up
Old 05-14-2002, 12:26 AM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
My friend Marshall is running 13lbs of boost on a stock clutch and he hasnt had problems. I guess it all depends on the motor and the driver.
95 Integra GS-R
[email protected]
Old 05-14-2002, 09:42 AM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
turbo isnt going to do much damage to the clutch. its the engine you want to worry about. on a stock engine you really dont want to give it more than 6-10 depending on the mileage. a new engine i wouldnt boost more than 7, but around 30k you could feed it around 9 safely. then lower it again as it gets older.
it has nothing to do with the driver (unless the driver drives slow and doesnt rev over 4000) on how long your engine will last.
but if the engine is built up enough you can give it a lot of boost. is this a daily driver? or just some weekend car? it depends on how many miles you usually put on it to decide how much turbo to give it.
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
Old 05-14-2002, 08:35 PM
FBP Si 2000 FBP Si 2000 is offline
Send a message via AIM to FBP Si 2000
I'm boosting at 5psi and my stock clutch it slipping already...Mind you, I only had 9425 miles on the clutch before the turbo went in. It will hold fine once you are in gear, but don't expect to do high rpm shifts much because it will not hold the power.
'00 FBP Si
sr20det how much boost is too much ??? 180sx-dude 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 03-10-2008 12:41 AM
How much boost with stock turbo using a boost controller?? aussie r33 General Discussion 5 06-19-2004 09:43 PM
how much boost to run on modded mr2 turbo TEAM KLR MR2/MR-S 4 04-08-2004 08:31 PM
95 integra ls: what type of TURBO & how much boost? 95 teg ls Integra 6 04-21-2003 07:39 PM
How Much Boost??? vernonhonda Forced Induction 4 03-22-2002 12:34 PM
