Old 05-02-2002, 07:35 PM
iwannablkmax iwannablkmax is offline
Send a message via AIM to iwannablkmax
timing belt probs
any body here every replaced a broken timing belt. ive already started taking basically the entire engine apart to get the timing belt cover off. i have a 91 civic LX 4dr with the 1.5 well right now im stuck i cant break loss the nut that holds the lower driveshaft pulley (the one thats connect to the crank that turns the pistons) anyway any suggestions on how to get this off? is it a left hand thread? any help would be great guys! thanks
words to live by: drive it like you stole it.
Old 05-02-2002, 10:25 PM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
is the belt broke? or just old? did it break while the car was running? if it did..then dont fix it. at least not yourself. ger a pro to do it. your engine might be a little fucked up..or a lot.
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
Old 05-02-2002, 10:48 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
The timing Chain..or belt .. is supposed to be changed every 100,000km.
I had mine replaced when i first bought my car (152,000km).
I would suggest you take it to a shop. It's a tricky job, I think they need to lift your engine to get it out.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 05-02-2002, 10:56 PM
yep it broke at 75mph on the interstate! so i figure i have some valves bent. which im not even gonna try doing that myself. but i figured i could do the belt. and got a hanes manual but the damn nut wont budge on that lower pulley. so i guess im screwed either way.
Old 05-03-2002, 07:12 AM
civic1991 civic1991 is offline
Send a message via AIM to civic1991
To fix the values you have to take that cam out. So I would just take the motor to a shop and have them look at your values. when that happened to me it was just easier to get a new motor, cheaper too.
**DO YOU RACE OR JUST RICE**
What do those Altazzas add, like 15Hp? HAHAHAHAHAHA!!!!!!!!!!!
Old 05-03-2002, 07:28 AM
it's gonna suck a lot to fix that.
heh..might be cheaper..and faster..to buy a new engine.
Old 05-03-2002, 10:09 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Cool
I think a ZC swap is in order
That will be cheaper than fixin' the mighty 1.5L - My Dad (the cheapest dude in the world) paid $1200+ to fix his Accord motor after he was too lazy to replace the timing belt and it broke (and bent some valves) at 125,000 miles.
ZC's can be had for about $5-600 and a cheap ECU for $100 - To do it right (replace the timing belt, water pump, plug wires, good ECU etc..) might cost $1000.
To answer your Q - A good strong impact wrench may be needed to break that bolt loose....or a big long pipe on your quality breaker bar. They are a bitch...and since D-series motors spin backwards, as they spin they tighten the bolt, which I think is why they are always so F%#@ing hard to break loose
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 05-03-2002, 11:38 AM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
hahahahaha welcome to my world three months ago. i broke about 5 different tools trying to get tht bolt loose. i ended up jamming a screw driver in the clutch and putting about a 5 foot breaker bar on it. good luck.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 05-05-2002, 05:05 PM
an update here for yah a few days later. i have a friend who wrecked his gsr integra (im guessing its the b 16 or 18?) anyway my cheap dad also said no way. so point is i talked to a friend who has a shop and it takes a 450 ft lb of torque to break that hoe! and my air socket thing only puts out 130 so hes gonna let me borrow his and i hope that will work. and i hate to go against my honda roots but im getting a 240 and swaping out for the sr20det from japan. but im keeping my honda and will always be a honda guy at heart
Old 05-05-2002, 06:46 PM
One of my budies had a 91 240sx Special edition.
I raced him and beat him only by a 1/4 car lengh.
But they are pretty good cars. and if you did swap the SR20DET
you would be HELLA fast.
Anouther guy i know did that to his 240. Then stuck a turbo, intercooler, ect ect on it. and he was pulling some pretty crazy times on the track.
Here's his web site http://www.angelfire.com/ok3/lieusr20det/
good luck with the 240
||JEFF| |
Old 08-24-2002, 11:02 PM
BullShifter's Avatar
if your timing belt broke at 75mph you got more than just bent valves
holes in the pistons
Old 08-25-2002, 06:38 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Ouch - they don't call them an interference motor for nothing
Timing belts should be done every 80,000kms according to the maintainance schedules over here. Me? I'd take that as gospel and not take a chance.
Easiest bet is to take it all to a mechanic as it's a pain to do without the right tools.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-25-2002, 11:01 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Yeah somethings aren't worth doing yourself.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-25-2002, 11:13 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i dunno you guys! jer's 88 accord just quit...and it was a busted timing belt. didn't want to mess with the vaccuum hose hell car anymore so sold it for $200. the guy who bought it threw a new timing belt and it and it started right up and runs like perfect.
i would replace the belt and see what happens. f*ck it. start it. so what if there is a bent valve...as it is you don't even know if it will start. then again..if you're worried and want to preserve the engine...change the belt and then tow it to a mechanic and let them check for bent vlaves.
i've seen some wicked crazy stuff (cam gear slipping 20 degrees while car was running, no damaged happened...another crazy example) when it comes to honda...anything is possible. like i said, it just might be a busted belt and that's all i have my fingers crossed for ya.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-25-2002, 11:26 AM
91civicDXdude's Avatar
i know this sounds like a load of bull but i swear its true. my crx parts car that i bought has 320,000 miles on the odometer and i took the engine apart.....factory timing belt. Hondas are built to last i guess.
Oh man, Timing belt probs I've never seen Ninety7PrixGT Contour 7 10-05-2010 09:52 AM
Timing belt walk HELP! 91TSi_ Engine, Transmission and Drivetrain 13 10-15-2009 02:47 PM
Timing Belt kp055174 Accord/TSX/Accord Hybrid 2 07-27-2009 12:00 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
