Old 05-02-2002, 05:00 PM
Laker's Avatar
Laker Laker is offline
Rattling Sound from undercar? Help!
anyone have this problem?
I get a LOUD rattle in low revs in reverse and 1st gear?
and sometimes at idle
Sounds to be coming around the cat, just a rough guess
Any suggestions?
its a metal on metal sound
Old 05-02-2002, 05:04 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
sounds to me like one of your heatshields is loose. pretty easy to fix with a large hose clamp
Old 05-02-2002, 05:05 PM
91zc 91zc is offline
Might be the heatshield on the cat or the heatshielding that protects the car from the hot exhaust. Just put the car on jackstands or on a lift and take a look for something loose underneath.
91 civic 4dr
b16a
14.8@94
Old 05-02-2002, 05:06 PM
Laker's Avatar
Wheres the heatsheild? right below the cat?
Old 05-02-2002, 05:09 PM
There is a hetshield bolted around the cat and there is also heatshielding above the exhaust system on the undercarriage
91 civic 4dr
b16a
14.8@94
Old 05-02-2002, 05:10 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
Yea I have the EXACT same noise, I jacked up my car onto a tilt and revved the engine to listen and feel where its coming from.. When the mid pipes flow exhaust out they vibrate and the heat shield is not touching your mid pipes completely, leaving a 1-3 mm gap so thats where your noise is coming from. I grabbed the pipes with a cloth and it stopped. I know fourthgenhatch found this aswell all you need are some pipe clamps and fasten it around the pipes and heat shield so they cant vibrate. I cant find the right parts so I'm taking it to a muffler shop...mo money.
When I step off the gas right when its idling the vibrations will start for a few seconds and then go away, thats all...
blah
Old 05-02-2002, 05:11 PM
EightOhOne's Avatar
usually the reason its loose is because the metal rusts where its bolted to the car. just take a broomstick while its running, and put pressure on the exhaust in different areas till you find the rattle
Old 05-02-2002, 05:17 PM
tbk49's Avatar
Just look at your piping, at the curves of the pipe theres another layer of flat metal between the body and the pipe. Just jack up your car if you dont know what i mean.
blah
Old 05-02-2002, 07:34 PM
CRX586's Avatar
CRX586 CRX586 is offline
I had the same problem (especially when the AC was on) so my mechanic took the heatshield off... now I'm wondering if that was such a good idea...
Old 05-02-2002, 07:41 PM
iwannablkmax iwannablkmax is offline
Send a message via AIM to iwannablkmax
im gonna go ahead and say i had the same rattle. and i used the ol broom stick thing to find were the rattle was and it ended up that i was missing a bolt down by the cat. end of story.
words to live by: drive it like you stole it.
Old 05-02-2002, 09:04 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Problem Solved. But I have a new even better Cat now...
Built in sheilds
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Venture 2002- raspy/rattling sound from heater fan/vents shelley748 Venture 7 12-28-2007 06:08 PM
Rattling sound from the brake booster. Calgary ZR2 Problem Diagnosis 2 10-03-2007 09:14 AM
Strange rattle sound from rear of engine or tranny texaslawman Windstar 7 05-05-2006 10:39 PM
Rattling sound from wheel arch area. 92 Prelude! gibraltar_lude Prelude 4 12-07-2004 06:47 PM
rattling sound from headers SlammedCivicSedan Engineering/ Technical 6 03-03-2003 03:45 AM
