Old 04-05-2002, 06:16 PM
parkcaka parkcaka is offline
il orange peel effecto?
i started my Mercedes-Benz CLK DTM 2000 Team Warsteiner kit as my order just came from hlj. i primed it with gray tamiya primer several coats. then i sprayed TS-14 2 coats for 2 days. After those 4 coats the paint have this orange peel you are talking about. im also building a mini cooper and i did same steps (except used white primer) and its soo shiny even without compound and polish.
so is my problem the gray primer, or do i need more coats. gray primer leaves a surface lot more sandy than white primer that may be the problem. also what im experiencing may not be a problem at all too. will this orange peel effect becomes shiny if i do compound and polish?
Old 04-05-2002, 06:30 PM
daggerlee's Avatar
compound and polish will remove the orange peel
you need to make sure your primer coat is very smooth before applying your color.
Dan
Old 04-06-2002, 02:53 AM
thanks
Old 04-06-2002, 04:11 AM
oh i found the answer to my problem!!! for the last coat (after i wrote the thread) i heated the can for about 5 min in hot water and it reaaaally shines. so what a fool i am, dan told about 50 times about heating the can but i just forgot about it for the first few coats.
Old 04-06-2002, 10:02 AM
MaxSE's Avatar
MaxSE MaxSE is offline
Whats' the science behind heating the spray paint can? why does it shine more. I've never tried it myself,is it becasuse the heat separates the paint molecules more evenly?!? what's up with that?
Say NO to wheel gap...
Old 04-06-2002, 10:42 AM
daggerlee's Avatar
http://www.tamiyausa.com/product/pla...clacquers.html
Dan
Slight orange peel?? Davoaldo Car Modeling 1 04-20-2003 09:15 PM
Avoiding Orange Peel! ...Need Help! jeru Car Modeling 12 04-10-2003 09:10 PM
Help Massive Orange Peel!!!! turbo2nr Car Modeling 7 04-01-2003 10:11 AM
Questions on what to do with orange peel RX7FD Car Modeling 4 12-26-2002 04:01 AM
Super fine sanding film and orange peel ? RyanGiorgio Car Modeling 14 12-09-2002 12:06 AM
