Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 03-29-2002, 12:35 PM
Grendel's Avatar
Grendel Grendel is offline
280zxt vs eclipse gst?
ok, there is this girl at work with an eclipse gst (90 something? not sure what year) its an automatic with some kind of exhaust... i think its just a muffler... but anyways...
I was wondering if my bone stock '83 280zxt 5spd could keep up/win against her eclipse?
My Z is supposed to have something like 180hp at the flywheel, but then again its almost 20 years old, and probably a little tired
-Grendel
Old 03-29-2002, 12:36 PM
crunchymilk555 crunchymilk555 is offline
why dont you race her?
Old 03-29-2002, 12:58 PM
Grendel's Avatar
Well, I would race her, but my car is in the shop getting 6 new injectors, a new exhaust gasket, and mabey a new exhaust manifold if the old ones cracked...
And I still wanna know if I have a chance before I try it
-Grendel
Old 03-29-2002, 03:11 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
She would probably win. those gst put out about 210hp wich would be quite a bit above 180hp.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 04-02-2002, 10:13 AM
utvolman99 utvolman99 is offline
Thumbs up You stand a good shot...
She is making a little more HP than you 210 to 180 (by the way both of these numbers are at the rear not the flywheel) but you are runninng a five speed and should weigh about 400lbs less! 180Hp should get you about 14.8sec in the quarter in a 3000lb ride. 210 hp would be about as fast in a 3400lb ride. Looks pretty even to me, if your cars not too tired I say the five speed will do her in. Also, you may want to check into dialing up your boost a little. Im not sure how to do it on your car but if you search the net I bet you can find something. You can bump the boost up on most cars by three or four psi for free by modding the waste gate. This should be a safe and easy mod since your getting new injectors and all.
Old 04-02-2002, 10:54 AM
CAptynCrunch CAptynCrunch is offline
I'd say go for it, the combined advantage of the 5-speed, plus the weight advantage gives you a fair chance, if not the advantage. Because although the GS-T has about 210 HP, it's a freaking bath tub compared to yours seeing as how it weighs 3100lbs. Now I'm not an expert on the datsuns from that time period but I'm pretty sure your car can't weight more then say 2600-2700lbs, which gives you a 400 or more lbs. advantage. I say go for it.
Keiichi Tsuchiya isn't the drift king,
Michael Schumacher Is.
The only thing better than cars is Music... maybe.
Old 04-02-2002, 12:08 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I doubt the GS-T has 210HP. I have seen the turbo on those and it is tiny compared to mine. My car is rated at about 205HP and I kill stock GS-Ts and GSXs all the time. Ah, but I don't really know, I am sure you guys have looked it up. Anyhow; I say go for it, I bet you could take her.
Old 04-02-2002, 12:16 PM
NSX-R-SSJ20K's Avatar
NSX-R-SSJ20K NSX-R-SSJ20K is offline
Send a message via AIM to NSX-R-SSJ20K
GST's aren't that much i know they're not they're around 175
Qualified Automotive Engineer
Old 04-02-2002, 12:52 PM
Well well well, i just learned something interesting. The GS-T isn't AWD. It's FWD. And yes it does produce 210HP. I was wrong, it only weighs about 2900lbs, but since it's FWD, that gives you the advantage still. I was always curious as to what the difference between a GS-T and a GSX was, now i know
Old 04-02-2002, 01:09 PM
o it does come to thing of it i do remember something about 210hp
hahaha the GSX is better but probably is slower due to the AWD
i think you should get a RB26DETT and shove it into your car (that would cost quite abit) but it would be great fun to see peoples faces when you mash the throttle and hear some chirps from the dump valves
Old 04-02-2002, 03:36 PM
One more thing...
Here is another little trick that worked well on my old 83 ZX NA. If you dont live in an area that does emissions testing you should gut your cat! The stock cats are really bad to close up over time. Mine started to really run crappy and the problem gave me fits forever! One day I looked under the car and the cat was cherry red! Removed the muffler, took a long pry bar and busted the element up. You need to have the car running while you do this. That way as you break up the element you can rev the engine and blow the crap out the back. It made a TON of differnece for me! I could feel it for sure in the seat of the pants meeter!
Additionally like I said do a search on 280ZX performance. You should be able to find a free - $20 mod that can up your boost a few psi that will make the biggest difference!
Old 04-02-2002, 03:56 PM
Re: One more thing...
i used to work at a garage where they sold cars as well as fixed em (tossers they were) anyway they'd rev the engines to blow the rap outta the cat all the time all the sudden it would go poof and this black crap would fly out the exhaust then it would drop a note or two and they'd ease off
Old 04-03-2002, 05:42 PM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
did a little research and came up with this. A stock 1983 280 zx turbo runs 0-60 in 7.3 sec. While a stock 1990 eclipse gs-t runs the 0-60 in 7.4
It would be a close run if both cars are in top notch running condition.
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 04-03-2002, 05:59 PM
add 20 years of wear and tear to the equation .............
Old 04-03-2002, 06:02 PM
Grendel's Avatar
I was thinking about some kind of a motor swap... I was looking at the 90-96 300zx twin turbo motors, but they seem to have high repair bills, and are pretty expensive...
There was a wrecked Skyline on ebay with the rear completely destroyed which came with a fairly low mileage complete engine/turbos/wiring/drivetrain/etc for 6k... If I had 6k, believe me, it would be mine :P I just gotta get outta debt first, and I'll either rebuild the motor outta my '81 280zxt, or buy another motor to swap in... A v-8 would be fun, but I really like having turbo over having tons of cubic inches (having both would be nice tho)
-Grendel
95 gst streetricer687 Eclipse Problem Diagnosis 5 03-08-2010 08:49 PM
Eclipse GST vs Eclipse GT (both auto) Savior1974 Street Racing 60 10-03-2005 06:54 PM
New to eclipses, got a 1993 eclipse gst with bad bottom end?? jslamerman Off-Topic 1 08-05-2005 05:54 PM
95 probe GT?? 91 eclipse GST 94tegRS Integra 2 08-31-2002 09:37 AM
audi S4 vs. eclipse gst kidrocket Street Racing 17 03-25-2002 08:53 AM
