Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-04-2010, 11:46 PM
streetricer687's Avatar
streetricer687 streetricer687 is offline
95 gst
have 95 gst w/ turbo wont start it ran then let it sit will try to start but wont catch and fire any suggestions?
Old 03-05-2010, 12:00 AM
Re: 95 gst
by the way it has new oil lines, valve cover, and kevlar timing belt
95 gst
turbo w/ intercooler
motegi mr718 in. rims
apexi cat back
eibach suspension
Old 03-05-2010, 03:00 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 95 gst
Did you just change the timing belt? Maybe it's out of time and that's why it won't fire correctly... We need some more details of what happened prior to this or what you may have changed so we know where to start with this. Also, can you give us a little more description of the problem? To me it sounds like your explaining it as it's just not firing but is turning over. Right?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-07-2010, 10:35 AM
Re: 95 gst
yes the timing belt is the only thing the car ran fine but sat all winter went out it try and start and it would turn over but not fire
95 gst
apexi cat back
eibach suspension
Old 03-08-2010, 02:55 AM
Re: 95 gst
So it ran fine after you changed the timing belt and only thing since has just sat parked all winter? Did you pull your plugs to see if your even getting spark at all? If not then trace back to the coil pack and test it to see if the voltages are correct on each of the coils.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-08-2010, 08:49 PM
Re: 95 gst
no i have done any of that but ill get it checked thanks
95 gst
apexi cat back
eibach suspension
Tags
eclipse , gst
