Old 03-22-2002, 12:14 AM
asnrefugee asnrefugee is offline
Send a message via AIM to asnrefugee
RSX type-s motor into a 99 civic
No more B-series engines.
Oh wells.
I seen a wrecked type-s at the local junk yard and the engine it totally fine.
Think I can swap it?
I never heard of anyone doing this swap and I was wondering if anyone knows how hard it will be.
HELLS YEA....6-SPEED!!!!!!!!!!!!!!!!
Old 03-22-2002, 01:16 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: RSX type-s motor into a 99 civic
Oh wells.
Well i heard rumors that HaSport is making K-series mounts? Then again its rumors though. It'll be kool if u can swap that thing into your civic though.
Old 03-22-2002, 05:40 PM
MadDog06 MadDog06 is offline
Send a message via AIM to MadDog06
one problem - the RSX-S engine spins the opposite direction of your of your original civic's. This i am about 99% sure of. can it still be done? maybe(?), with enough cash, hopes and dreams (not to mention sweat and hard work)
Edit: yes. i have found the article to confirm "Don't count on using any B-series knowledge on the new K20; it is a different beast in every way. First, it rotates clockwise, where the b18 rotates counterclockwise..."(SportCompactCar Volume 13, NO. 07; July 2001)
Old 03-23-2002, 09:43 AM
1995HondaCivic's Avatar
1995HondaCivic 1995HondaCivic is offline
Send a message via AIM to 1995HondaCivic
that would be hella crazy and hella expensive
Old 03-23-2002, 10:32 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
yea exactly...that would be crazy and kinda expensive....i guess it MIGHT work tho. I guess u could be the first to find out.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-26-2002, 02:35 PM
justanothermike's Avatar
justanothermike justanothermike is offline
Send a message via AIM to justanothermike Send a message via Yahoo to justanothermike
u can swap that into a new civic
Old 03-26-2002, 10:35 PM
vtechnique vtechnique is offline
the rotation direction of the engine would only matter if you are trying to matt a K20 up to a normal gearbox.. THAT wouldn't work !!
but if you are swapping in K20 with the 6-speed you should have no major hassles once you've sorted out the mounts and the drive-shafts..
Having seen a new type R ( RSX type S ) on the dyno after an old integra type R B18C-5 went on.... the new motor BOOTS !!
go for it man !!
Old 08-01-2002, 07:15 PM
FastFuknCivic FastFuknCivic is offline
Send a message via AIM to FastFuknCivic
Exclamation Is it possible??? YES!!!
I have a link to a website that did the exact swap you are talking about....here is the link, i am looking for an rsx-s engine myself to swap into my 93 civic coupe ex....good luck
http://tech.hybridgarage.com/tech/7gtech/7g-swap.htm
Old 08-01-2002, 08:03 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
Re: Is it possible??? YES!!!
mind you that its a 7th generation civic that they are swapped into. i don't think it will be an easy task swapping that engine in, and also making it run. besides..no one wants a 6-speed reverse and only 1 speed forward. u can probably turn the chassis around so it'd be a rear wheel drive mid engine car. muahaha. ok. i'll stop with the ideas..
Old 08-02-2002, 02:56 AM
BurgerBoy's Avatar
BurgerBoy BurgerBoy is offline
I like stuff!
Send a message via ICQ to BurgerBoy Send a message via AIM to BurgerBoy Send a message via MSN to BurgerBoy
An EK Civic with a K20A DC5 Type R swap.
http://www.honda-tech.com/zerothread?id=236529&page=1
http://www.dogbite.co.nz
MSN: [email protected]
AIM: pureJDMteg
Old 08-04-2002, 03:45 PM
Prelude engines rotate opposite to Civic engines also. Last time i checked you could put an H22 into a civic so why couldn't you put an RSX-S in it? But anyway are you telling me that the 7th generation civics rotate different than the 5th?
Old 08-04-2002, 04:36 PM
luti luti is offline
Send a message via AIM to luti
You all seem a little confused. Actually, everyone but vtechnique. The direction of rotation only matters if you are using a transmission from a B series engine. But who would want to do that, why not just use the 6 speed manual the K20's already bolt to. It would be an extreme amount of work to mate a B tranny to a K block, and then you would have the reverse rotational issue.
T3/T04E turbocharged ricer.
vibration problem need an expert my rsx is falling apart need HELP!!! 2003rsxtypes Let's get Technical! 1 09-27-2009 05:48 PM
RSX-type S motor info hybridtheory2o N2O | Turbo | Superchargers 9 02-24-2006 07:05 PM
RSX-S motor into a Civic bishounen69 Let's get Technical! 15 05-24-2004 12:54 PM
2003 RSX TYPE S INTO 4g4d travagliante '88 - '91 Civic | CRX | Wagon | Shuttlee 47 05-14-2004 04:04 PM
1st Successful RSX Type-S (K20A2) Engine Swap into a 7th Generation Civic EX! 2k2civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 08-03-2002 01:40 PM
