Old 03-20-2002, 06:44 AM
MaFi0s0 MaFi0s0 is offline
intake
i read somewhere that if you have too much intake its bad at low revs, thats why you can get dual intake system with a small airfilter and big one(simular to twin turbo)
but i went to the k&n airfilter site and it says the bigger the intake the better.
Old 03-20-2002, 03:49 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Sort of true, but your wording is wrong. Dual intake does not come from the air filter size, it comes from the manifold. A shorter manifold is used at high revs because the air doesn't have to travel as far to reach the engine. A long manifold is used at low rev because the engine is not breathing as fast, thus the air will not have to travel as fast. That's what dual intake manifold does.
Old 03-22-2002, 03:23 PM
i get it, thanks
What Edelbrock Intake should i go with? inforcer958 General Discussion 4 02-14-2011 07:58 AM
Intake problem? Frankp87 C/K 7 02-12-2011 07:35 PM
cold air intake created by using an intake pipe and a stock intake tube is this OK civic95 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 06-22-2004 02:04 AM
Stillen Intake/JWT Intake CharlieDigital Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 13 01-07-2004 12:01 PM
I want Intake, JWT Pop has pipe or no? I want pipe, any Intake I can get with it?? DJ Hotpokit Engine 2 10-28-2001 09:27 AM
