Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-11-2011, 03:03 PM
inforcer958 inforcer958 is offline
Cool What Edelbrock Intake should i go with?
I have a 1985 El Camino with a 350 swapped into it from a 1974 c-10. I am currently running a 600cfm Edelbrock carb, a Performer Air-Gap intake pt #2601 and full length headers. No emissions equipment other than cats.
I recently did some work to the engine and the front screw mount there the alt bracket bolts on has broken away. So i need to get a new Intake. I want to stay with an Edelbrock intake but don't know what to get. It is used for mainly cruising and sometimes a daily driver. But i really enjoy the power out of it. I was watching an episode of horsepower tv and they showed that putting a different intake on the car can hurt you even tho it might be more expensive and "improved" So....Can someone send me in the right direction?
I appreciate all the thoughts. But i don't need anyone telling me to get a different brand.. The carb, intake, valve covers, and air intake are all Edelbrock now, and would like to keep everything matching!
Thanks
Old 02-11-2011, 03:25 PM
mcmalloy mcmalloy is offline
Re: What Edelbrock Intake should i go with?
check there web site for current street intakes , there is alot to choose from
Old 02-11-2011, 06:10 PM
777stickman 777stickman is offline
I would say if you're happy with what you have then stick with it. I had to replace the performer manifold on the old VanDura a couple of years ago for the exact same reason and I replaced it with the same Performer manifold without hesitation.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-13-2011, 04:47 PM
I do enjoy the intake that i have. But its the only intake i have had since i have had the car. It was put on by someone that i am sure didnt know a whole lot about engine. It was originally put on a 305 and then i put it on the 350. So i guess my question is. Should i be looking for an intake for RPM at idle - 5500? or RPM at 1500-6500? For this stock engine?
So performer Air-Gap, or the RPM Air-Gap?
1985 Chevy, El Camino, 350, 4bbl, Full Length Headers, 600cfm Edelbrock Carb, THM350
1992 Chevy, Camaro, 3.1L MPFI, BONE STOCK
Old 02-14-2011, 07:58 AM
MrPbody MrPbody is offline
AF -Advisor
Performer is the manifold of "choice" for engines operating under 5,500 RPM. If you want more revs, RPM is called for. The "Air Gap" is a good feature for more performance-oriented applications. It prevents the exhaust heat from making the intake "hot". If you use a "hot air" choke, the Air Gap is not a good choice. If you have an electric choke (or NO choke...), Air Gap is the good one.
IMO, there are no better intakes on the market than Edelbrock. They wear engines out testing.
Jim
Tags
350 , chevy , edelbrock , intake
