Old 03-06-2002, 03:32 AM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
Primer and paint incompatibility?
I had problem with Testors primer and Tamiya spray (and will never use it again). As the primer lifts the paint getting cracked
I also found Duplicolor automotive paint getting cracked if applied over Tamiya primer. Never know what's going to happen when use it for the first time
Current project: Tamiya Porsche 959, red
Old 03-06-2002, 07:13 AM
daggerlee's Avatar
Sounds like the primer layer is still releasing excess gas
Did you wait 24 hours?
Old 03-06-2002, 04:39 PM
primera man's Avatar
"P-Man"
Keep to the same brand of primmer and paint to save a lot of hassle.
View All My Models Here.
Old 03-06-2002, 07:22 PM
I know it's the best way but there are some exotic paint suppliers like MCW Autofinishes and Cobra Colors. I'm gonna use 'em for factory matching colors and don't know how it react with my favorite tamiya primer
Anything good about Gunze Mr.Surfacer? It's kinda expensive here (~$8 for spray can). Worth to waste money?
Old 03-06-2002, 07:48 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Certainly, experimenting Gunze is worth the money. And it won't be wasted unless you stop modeling. My experience with Gunze and Dupli color combination is that it works well. However, heavy wet coat of Dupli Color will definitely dissolve completely dry Gunze.
No matter what brand you use, the rule of thumb is...
* Primer has to be thoroughly dry
* First few coat should be almost mist-like light coat
As long as you stick to those, you can even use incompatible primer/body color combination when desired color is not available in appropriate paint type.
Hiroaki Fukuda
Old 03-06-2002, 08:00 PM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
Cobra Colors has ceased operation as of the beginning
of February,
Leon said I was TOO profitable to keep as a part time thing but
not good enough to make it full time.
enamel and lacquer are not compatible !
Old age and treachery will overcome youthful exuberance everytime !!
Question abouty Primering and Painting **** AbsoluteGTR Off-Topic 7 12-19-2005 10:56 PM
Tamiya paint with duplicolor primer and duplicor clearcoat? patoffspyder Car Modeling 5 08-20-2005 06:48 PM
removing rust and primer to paint cwmacqueen Camaro Discussions 2 04-14-2004 12:43 AM
primer and painting Modelcargarage Car Modeling 3 03-02-2003 09:02 AM
Duplicolor automotive primer and tamiya spray paint Daryl Car Modeling 4 07-01-2002 10:02 AM
