Old 09-19-2004, 12:50 PM
XactoKnife XactoKnife is offline
What do you start with first?
Just wondering what the norm is....
When starting a new kit, what does everyone normally start with... the body or the smaller parts?
-Xacto
Old 09-19-2004, 01:16 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: What do you start with first?
The body and things that have to fit to the body. This way, the body can be at the beginning of the paint sequence, and can dry while I do work on the rest of the car.
Old 09-19-2004, 01:26 PM
freakray freakray is offline
AF Modelrater
Most of your questions have been answered before, using the search feature should answer them before you have to post them.
As for this one, I start with all the parts that require modification to be accurate, everything else will fall into place from there.
AF User Guidelines
Old 09-19-2004, 01:37 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Every single one of my models has to be custom, period. So first thing I start with is the design. Then I build the body to that design. After that, I decide to make sure everything fits. So basically I build everything around my original design.
-Mike
Old 09-19-2004, 01:41 PM
GT-Alex's Avatar
GT-Alex GT-Alex is offline
Send a message via MSN to GT-Alex
I usually start by studying the instructions, to see how the kit will be mounted/painted. Then i test fit all the parts and start the buildup.
Old 09-19-2004, 02:29 PM
Spitfire7's Avatar
Spitfire7 Spitfire7 is offline
I follow the instructions, i try not to skip ahead otherwise it might come out wrong.
Old 09-19-2004, 03:33 PM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
It depends. On a box stock build I paint the body first. With havily modified cars I always start with engine, suspension. I modify everything and after that I paint everything.
Old 09-19-2004, 03:42 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
It really depends on the kind of car you are building. When I build my Nascar's I start with the frame and the roll cage. But for alot of other cars it's best to start with the body. Get all the parts fitted and get it painted, that way when your ready to attach the body, it will have plenty of time to dry and you won't have any problems.
Old 09-19-2004, 04:25 PM
ToyTundra's Avatar
ToyTundra ToyTundra is offline
Re: Re: What do you start with first?
My favorite place to do that is on the crapper.
I agree with Bas Carwash 100%
Old 09-19-2004, 05:23 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
Re: Re: Re: What do you start with first?
Test fit and then spray the body first. Like Willimo said it is best because as it dries you can work on the rest of the model.
I think that is just one of those things that we keep to ourselves.
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 09-19-2004, 05:32 PM
RallyRaider's Avatar
Zomby Woof
I kind of do everything in parallel. However the body is usually the piece that requires the most work. So naturally it gets the focus, especially early on.
Old 09-20-2004, 03:49 AM
_WIDE_LOAD_'s Avatar
_WIDE_LOAD_ _WIDE_LOAD_ is offline
Send a message via MSN to _WIDE_LOAD_
I usually sand and prime the body. Then build everything else (starting with chassis and any mods that need to be done).
My name's Troy, use it if you like.
If you're a Buddist, you go to Tibet....If you're a speed freak you go to the Salt Flats
351 clevo....aussie muscle
Old 09-20-2004, 08:29 AM
Vric's Avatar
Vric Vric is offline
Body
I finish the body before doing anything else.
So the body have plenty of time to dry when I work on the rest of the kit
Old 09-22-2004, 03:43 AM
Im glad to hear that most finish the body first. It means that I'm doing anything wrong. heh heh
Old 09-24-2004, 01:52 PM
mike united's Avatar
mike united mike united is offline
Study instructions (on the crapper as someone else mentioned) then go through the body process bit by bit leaving it all to dry properly for a few weeks while i get on with the rest.
Mike
