Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 01-24-2002, 10:44 PM
Koojo's Avatar
Koojo Koojo is offline
Send a message via AIM to Koojo
Quick Help On Stillen Intake
Im probably going to buy the Stillen intake for my 00 G20 in about a week. Im going to order it from my auto shop, i think they charge like 155 or 160 for it.
My first question:
1. When I order the intake for the 2000 G20, will it fit perfectly? Because I heard some talk about the adapters not fitting or something of that sort.
2. What to do when the filter gets dirty? Do I have to go out and buy a new filter? or what happens?
3. Does the stillen pop charger have a hole for the temp sensor to go into? and what happens with the old pipe that connects to the air box (that pipe is the one that holds the temp sensor right?)?
4. I also read that you have to reset the ECU after installing the intake, is that right? After installing the intake, will the Service Engine Soon light come on?
5. And finally, is reseting the ECU hard? Whats the main point of doing it, and HOW do is it done on a 00 G?
Im just trying to clarify all this stuff before I order it. Thanks everyone
Old 01-25-2002, 06:29 AM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
1. I've never heard of a fitting issue.
2. I believe Stillen uses an oem K&N filter. The K&N site says you do not have to clean it until 30,000 to 50,000 miles, but you should inspect it once a year. If its dirty/dark looking its fine. If the mesh is clogged, it needs to be cleaned. K&N also sells a cleaning kit if you are interested.
3. Not sure. But if it doesnt you can strap the sensor anywhere near the air filter. Its job is to read the temp of the air going to the intake. The pipe is removed and chucked. Or you can actually leave the pipe in place w/ the sensor in it (I'd remove it though)
4. You dont HAVE to reset it. Your engine light should not come on unless you broke a sensor or something.
5. Its not hard. It forces the ECU to re-learn. 2000 G? Sorry!!! you cant do it! Only on the 99 and older. The newer ones do not have the reset screw. The only way to do it is by using an OBD-II compatible Scan tool or the Consult. You can possibly do it by removing your battery cables for several hours, but I've heard conflicting reports on this.
Old 01-25-2002, 11:29 AM
Koojo's Avatar
does anyone know if the stillen intake has the hole for the sensor to go into already? I really dont want to drill.
Old 01-25-2002, 12:29 PM
kenchan's Avatar
kenchan kenchan is offline
does the stillin one fit a 2001?
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 01-25-2002, 09:16 PM
Koojo's Avatar
I think the it is the same for 00, 01, and 02. So I think it should fit, but dont quote me on it, have someone varify it for sure.
Old 01-25-2002, 09:20 PM
Koojo's Avatar
thanks for your help, but i got two concerns....first is the the CENSORS. how many do i have to deal with when i take out the old box and put in the new intake? is it just that one temp censor? does stillen have a place where to put it into , or how should I do it? can someone please explain it in detail for me if there is some other way of doing it.
Also, since im installing an intake on a 2000, and the car is still under warranty, the stealership shouldnt have a problem with this right? Its not doing any kind of harm to my car, it is in fact helping the engine breath better. So they wont be like, "you're warranty is now void" or something like that? Thanks
Old 01-25-2002, 10:17 PM
paradyme paradyme is offline
Exclamation
I have a 95'G20t with the STILLEN intake and it came with the holes pre-drilled. STILLEN does their homework usually. Yours should come predrilled. I have cleaned mine using the K&N recharger kit, let filter air dry. Works fine, no problems.
:flash:
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
Old 01-26-2002, 04:28 PM
kenchan's Avatar
oh ic, so 99 is the only different one...so should look for a 00+ version.
Old 01-27-2002, 07:41 PM
Koojo's Avatar
Can someone PLEASE answer this question for me!!!! DOES THE 00 STILLEN INTAKE HAVE A HOLE FOR THE SENSOR? sorry for yellin but i asked a few times already and no one gave a clear answer.
Old 02-10-2002, 10:55 AM
ronnie_g's Avatar
ronnie_g ronnie_g is offline
Question Reseting ECU
I just had my pulley's replaced w/ UR S. Do I need to reset my P10 ECU? I am waiting for my JWT pop charger this coming week. Do I need to reset my ECU again? Would it affect the coding of the radio, alarm, etc.??? I was browsing around for the ECU in the net and found some comments about making sure you write down you radio code & other system code stuff sh#%, etc....???
Please someone clarify this thing for me
I appreciate the effort in advance
Old 02-12-2002, 03:20 AM
pRiMeRaCeR pRiMeRaCeR is offline
Send a message via AIM to pRiMeRaCeR
If you specify that you have a 2000 model, then YES the stillen intake kit has a hole in the filter for the temp sensor. I am positive, because i have it.
What Edelbrock Intake should i go with? inforcer958 General Discussion 4 02-14-2011 07:58 AM
Quick help needed- (Classic Aurora)- Pressure Relief Valve on the Intake Manifold.. Viol8tor Aurora 1 04-05-2005 09:27 AM
Stillen Intake/JWT Intake CharlieDigital Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 13 01-07-2004 12:01 PM
Put in Stillen High Flow Intake today...Quick HELP Koojo Engine 14 03-29-2002 11:37 AM
FS: Stillen Intake, Stillen Exhaust, Stillen Braces, Fogs 2K1 G20 Classifieds 17 03-15-2002 11:46 AM
