Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-16-2002, 12:25 AM
b16b bomber b16b bomber is offline
Lightbulb b16a turbo???
anyone with a b16a turbo??
how much horses did you get out of it?
Ans how many pounds are you running?:alien:
Old 01-16-2002, 01:35 AM
pvang31019 pvang31019 is offline
a firend of mine made 314whp on(I forgot the boost)but it was around 12psi....on the dyno with 18" rims
Old 01-18-2002, 11:53 PM
Inspire95 Inspire95 is offline
Send a message via ICQ to Inspire95
What did they do to his internals to back that much pressure?
What turbo is he using? thanks!
Old 01-19-2002, 10:37 AM
stock internals...12psi is not that much. He's using the Drag3 SI kit....
Old 01-24-2002, 11:35 AM
MatT3T4 MatT3T4 is offline
Send a message via AIM to MatT3T4
I made a shitload of power on my B16A turbo. You don't need to build the motor until you hit around 350hp or so for a daily driver.
Just make sure you have ample fuel and spark, and good tuning. B16A turbo's are incredible.
Turbo Guru v1.0
http://www.MatT3T4.20m.com
Old 02-23-2002, 11:44 PM
SleeperCivic SleeperCivic is offline
Your B16 won't last very long if you push it over 9psi. Check out my site.
http://home.satx.rr.com/importvelocity/
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 02-24-2002, 01:29 AM
ummm....where in your site? I'm curious as to why you say this....My buddy's car has been running strong for 1.5 years....
Old 02-24-2002, 07:38 AM
It's just general knowledge from enthusiasts to shop owners that the rods of the B16 aren't designed for that much pressure, either from turbo or S/C. Sooner or later, they're gonna give. Probably sooner than later.
Old 02-25-2002, 12:43 PM
they musta had lemons....I've seen them run strong for years
Old 03-06-2002, 01:14 PM
Whatcha smokin'? It's not common knowledge that the B16A is a bad motor to turbo. It is common knowledge that the B16A is the best Honda motor to turbocharge. It has a near perfect rod:stroke ratio, and the internals are extremely strong, and can withstand years of punishment, make more than 350hp stock, and can kick the crap out of all other Honda motors.
You know what makes you think that it is a bad motor? I know the answer...it starts with a T, ends with a G, and has an UNIN in the middle. If you tune a motor wrong, it will die...even if it's fully built.
Turbo Guru v1.0
Old 03-06-2002, 03:22 PM
hahahah....rotflmao....
Old 03-06-2002, 04:09 PM
Never said the B16 is a bad motor. Just said it won't last long after 9psi. Thank you.
Old 03-06-2002, 04:23 PM
Have you ever turbocharged a B16A, sir? I happen to believe that you do not have any experience with this motor. Correct me if I am wrong. I ran a turbocharged B16A for 3 years. I built it after an injector o-ring broke, which was installer error...even after that, I ran it for another 7 months. I ran the car for about 20 months, daily driven, between 10-15psi.
9psi is an arbitrary number, and means different things from different turbochargers, therefore making it a pointless statement. A B16A can last just as long as ANY other motor, being driven daily well above 9psi. Trust me. I've done it...a lot...and so has every single other B16A I have ever seen, that was tuned correctly.
As I said before, you are being misled by improper tuning. If a shop told you, or someone else that the B16A blew because it was boosted more than 9psi, I would be willing to bet that, that was the shop that tuned the motor, and they fucked it up, and that is their cover. The B16A can last for years above 9psi...it's no secret. Please don't spread false rumors about this motor to prospective enthusiasts. The B16A is the best Honda motor to turbocharge, bar none. I don't mean to be jumpy against you, I just want you to understand that tuning is KEY, and that the B16A motor can last eons above and beyong 9psi.
Turbo Guru v1.0
Old 03-06-2002, 09:12 PM
Well, it's obvious you have more experience than me on the B16. I've been going from what I've been told. But, I just can learn from my own personal experiences. Most everyone I've talked to (on this post) will not go above 9psi before they upgrade the stock internals. That's what I've heard from a lot of people. Just to verify, my 99 Civic EX SOHC IS a B16, right?
Old 03-06-2002, 09:27 PM
I have tons upon tons of experience with the B16A, along with other Honda motors. Your motor is not a B16A, yours is a D16(something). The B16A first appeared in Japan in 1988 or 1989, in the EF chassis CRX's and Civic's. The B16A is the DOHC VTEC motor. It made its way to America in the DelSol DOHC VTEC models, and in the 99-00 Civic Si.
You have a D-series SOHC motor. The SOHC motors can handle some boost, contrary to what some believe. I used to have a D16Z6 (1995 Civic EX) SOHC VTEC with the GReddy kit on it. I pushed 14.7psi out of that fucker...had it running low 13's with the stock internals (except a GReddy 2mm head gasket). Trust me man, Honda motors aren't weak...it's just the poor tuning that kills them.
Turbo Guru v1.0
B16A all motor or B16A Turbo Lou09 JDM Motor & Parts info/chat 7 12-20-2007 02:53 PM
Have someone B16A+Turbo in Europe? MatikaS Europe 8 09-01-2003 03:15 AM
b16a turbo, fuel delivery q's Red_Liner740TIC '88 - '91 Civic | CRX | Wagon | Shuttlee 7 11-18-2002 01:24 AM
b16a turbo..what psi? Saki0 Forced Induction 0 09-23-2002 12:40 AM
B16a Turbo--> Cost Efficiency?? help Inspire95 Forced Induction 19 03-06-2002 01:21 PM
